  • Replies 49
KK so car got dynoed today 550cc injectors, hypergear hi flow and z32. Cars getting compressor surge... bad batch of fuel or poor dyno conditions. Car will get re dynoed next week in EFI performances new dyno cell with new fuel to try to correct the problem as the current dynob eing used for my car was poor conditions, Stale air etc. Just going to hafto wait till then :(
but you get to choose from a few different specs..
any of this sound familiar? ATR28? G2 profile, G3 profile? 71mm compressor wheel? 76mm compressor wheel?
what rwkw numbers were you pulling during that initial run?
its the G3 profile. As fo what numbers I made, I'll let you know when it gets re dyno'd as the main influences towards the bad tune atm are the dyno conditions and an extremely bad batch of vortex 98. It could be the manifold needs to be upgraded... not sure as of yet it all really jsut needs to be sussed out and have a good going over end of this week or beggining of next. The car only made 190rwkw's at 1.2 bar. And the timing is all out of whack atm.
Edited by Sammy34
Hrm Im starting to wonder now. The hypergear turbos are able to run 20psi or so they say. Im starting to wonder if the turbo being internally gated and running 1.4 bar of boost could be causing the compressor surge. As I cant seem to understand how the standard manifold could be causing a restriction bellow 250rwkw's. Here are the turbo specs, my car mods and a small bit of detail on the first dyno and what seems to be happening atm.
Hypergear hiflow
ATR28 G3 profile .63 has the larger OP6 rear housing.
Car has as follows:
Hybrid FMIC
AVCR boost controller
z32 AFM
Turbosmart Fuel Reg
HKS Fuel pump
Apexi Intake
550cc injectors
3" turbo back exhaust
splitfires
Nistune
etc etc. So basic mods.
Dyno run when I got the nistune donestandard turbo made 180rwkw'sat 13psi, everything was spot on.
Now after the hypergear turbo, injectors and z32.
its final power runs was set to 18psi, car was getting to around 250hpgetting compressor surge, overboosting and jumping to around 260hp at about 25psi. now the car had a bad batch of fuel in it I got earlier at a caltex, 98 ron of course. Dyno conditions were terrible as the dyno being used had no fresh air at all so the car hated it.
Im getting the car re dynod to fix up the problems but have been told that the manifold may be giving the car too much restriction. But I find it hard that the standard manifold would need replacing at such a low power level.
i guess it is possible. Might help if you're able to find out the compressor wheel size.
how do you know you got the larger of the OP6 rear housing?
looks like you've got all the supporting mods there, and i too agree that the manifold idea seems a little strange.
when's the next dyno run booked?
end of this week, beggining of next. Guys at EFI have bene a big help as there only jsut getting there dyno facility sorted out this week so there getting my car retuned for free as the other facilities were poor. As for the compressor wheel the guy from hypergear really didnt give me any specs to go buy, what I actually got in the mail was a turbo with a larger rear housing than what I ordered, sit the old turbo and new turbo side by side and u will see the difference. All I got from the bloke at hypergear was it was using to4 internals. I mite make a phone call and get the info right now.
oh so you didn't send off your old turbo??
nah nah, they ordered 1 in and made it up. Bloke from hypergear recons its the intake pipe sucking shut, the boost solinoid is rooted, boost controller is rooted or cam gears. :S
those intake pipes do suck shut, that's for sure....
hmm... guess you won't know until it gets back on the dyno.
did you have a specific power goal/figure in mind when you ordered the highflow?
Its a ATR28G2 CHRA. using the GT2871RS Comp wheel. It might be in a None OP6 R34's rear housing. The comp wheel is not big enough to surge and we’ve opened up the air gap to avoid surging. Its been dynoed 233rwkws in smaller R33's rear housing at 1.1 bar. It doesn't seems to be a turbo issue. Check in take pipe, EBC, timing and tune.
Yeh around 250rwkw's but the tuner strongly believes its going to do better than that on his first impressions. we just hafto see I guess. Im going to be running 1.4 bar and if everything goes well hopefully if first impressions last I cans ee around 260rwkw's although thats probably stretching the abilities of my gearbox a tad as the cars auto. Going to get onto upgrading that intake pipe though this week, if anything Id say that sounds like whats going on as Im sure those intake pipes arnt made for running 1.4bar of boost :)
look up the 'rev210 intake mod' if you want a cheap $5 diy solution.
or these guys sell silicone intake pipes that are up to the job. http://www.racespec.com.au/
good luck and let us know how you go because i'm very interested in your final power and how that spec'd turbo goes.
Im starting to wonder if my problem is being caused by my BOV hks ssqv, i believe there atmo bovs. Hrmm anyone with an idea? no one seems to be able to pin point where my problem is. I dont hear the bov sound anymore sinze the turbo upgrade... no pshhh just a dut dut dut dut dut sound when i come off the accelerator but i assumed that was due to running more boost.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
