hey pplz
im lookingut cant seem to find any anywhere!!!
Can you please post where i can find one or a few cos im thinking vertex but also something different to other peoples cos i wont my first build to be a unique one!!!
please need help bad
NOOBZ
https://www.sau.com.au/forums/topic/260776-r31-body-kits/
hey pplz
NOOBZ
kits for these things are really rare due to its age.
you may have to custom make one
this one looks pretty good......
http://s12.photobucket.com/albums/a229/rac...t=IMG_91932.jpg
apparently its got an RB26DETT
https://www.sau.com.au/forums/topic/260776-r31-body-kits/#findComment-4473748
That is an R31 house front lip (www.r31house.co.jp) Side skirts I am not sure about perhaps MOA Collage or something hard to find. CCS make kits for aus 31's and there is a uras kit as well.
Have a look through here to see what is/has been avaliable.
http://wiki.r31skylineclub.com/index.php?title=Body_Kit_info
Cheers,
Michael
https://www.sau.com.au/forums/topic/260776-r31-body-kits/#findComment-4477939
that's bombed... i'm not really a fan of kitted 31's, but i'd have that!
https://www.sau.com.au/forums/topic/260776-r31-body-kits/#findComment-4477957
Depends if its an import or local model.
Imports have two options, r31house or uras. R31house is stupidly expensive for what it includes and are only sold through powerplay which pretty much rules them out. The red 7th meister car above runs an r31house front lip.
Or hunt around yahoo auctions for one of the older discontinued kits.
cheers mitchy :)
https://www.sau.com.au/forums/topic/260776-r31-body-kits/#findComment-4477965
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
