Congrats on the purchase mate.
I believe Savman's is a genuine N1, no doubt he'll confirm.
As an aside, I believe the R32 N! was the only version to have the ABS deleted. I know the genuine R34 N1 I campaigned last year in Targa had ABS, and I'm pretty sure the 33 does too :wave: Savman's car does.
yep we rally a genuine n1, and the other n1 in tassie is a rally car too..... it's the reason they were made. running 1.3 bar of boost with the pfc boost control kit.
R33 N1's do not have ball bearing turbos. they run a bigger than std bush bearing steel wheel turbos. The N1 engine is much more refind than the std one, we run ours to 8500rpm
ABS was a delete option, never seen one with that box ticked though.
there is no need to replace the r33 airbox, it breathes realy well, as it's got 2 air intakes.
you don't want to sell the kevlar diffuser cheap do you :blink: i broke ours last year.
Nice!
Do let me know when the site is up. The N1 seems to be a myth to most people including myself. Not much is known about them. I would like to know the production figures and some technical specifications of the stock car. But apart from wiki there's nothing much I can find.
you don't want to sell the kevlar diffuser cheap do you :down: i broke ours last year.
Thanks for that buddy! :)
Heres the pictures. Unfortunately the car is gonna be sitting in the workshop for the next week as well... unless someone's got any suggestion on the a/c fix.
Currently the oil cooler is sort of in the way and is using 1 of the hole which the bracket for the condenser goes. What we thought of doing is
a) cut the oil cooler brackets off and let it hang in between the condenser radiator and intercooler (I dont really want to touch any of the stock parts)
b) bend the condenser and try to fit in between
c) talk to the a/c people and see if we can get a small condenser to fit or custom the current 1 to fit (looks like this is the way to go for now, cut the condenser and weld it. Only downside is maybe the a/c wouldnt be as cold?)
I thought the N1 oil cooler would be an after market part for some people. Dont know why it doesnt fit....
LOL! :P
N1 buddy!
It came from factory with NO A/C and you are trying to fit one... Haha!!
Yes N1's came with standard oil coolers.
Whats it gonna be..? Performance or Luxury?
:laughing-smiley-014:
Nice engine bay as it looks nice and clean.
BTW your air intake looks different to the other R33 GTR's. I thought there would be a big air feed which sits on top of the radiator..?
Your intake must feed air up from the bottom of the front bar.
well technically speaking I think cutting the condenser should work as well but it wouldnt be as cold (so I still get a bit of a/c, lol). Anyone fit the oil cooler on their gtst or gtr before? Please tell me howwwwwwwwwwwwwwwwww
I'm also thinking of getting a Kaki Regu 06&R (I love that titanium look) to replace the Trust TI (sad but I dont like to be a cop magnet). Anyone thats keen on buying the Trust please let me know. As soon I get the a/c crap done, I'll start hunting for the Kaki.
I didnt know so many things are illegal in Aussie (even boost controller)... and since its my first car, I dont have much clue on how hard do cops pick on imports.
redtop injectors?
its just the plugs...if you look closely at the 1st and 3rd injector in the 2nd pic you can see they are stock yellow GTR items.
Edited by DiRTgarage
Most of the time, aftermarket oil coolers are fitted down on the driver side behind the front bar where there is a vent to allow air to it.
Just hide your boost controller and your piping and solenoids in the engine bay and paint them black so it looks "Stock".
Haha!!
N1 should already have a nismo catch can on the passengers side. The N1 oil cooler is designed to take up the ac condencer & bottle space. My mate has a R32 nismo edition, and they came with a N1 cooler, but he has 1/2 a condencer that sits on the passengers side of the radiator. I'd be careful of putting a condencer between the oil cooler and ratiator. Just cause it's less air flow for the radiator.
Do you know what model the trust ti is? i'm after a 80mm Trust ti-r for the Targa car.
Edited by sav man
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
