hey there'
so my car is going to try getting rid of shuffle (RB26, garrett -5's) going back to standard BOV, dirtgarage said that the HKS balance pipe did a good job, but cant be bought anymore, and expensive around 1k?
my mechanic suggested making one up??????
any suggestions?
https://www.sau.com.au/forums/topic/260820-26-5s/
try the stock bovs first i do not get any shuffle at all :P
yeah crap, i have read so much stuff about this, but my tuner insist on not going back to stock because of the leak?
i dont really want to 'tell' him to put them back on?
but i should really aye
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4473989
they are ment to be good for like over 600kw are they not?
i only have 300kw atm on 15 close to 16psi but yeah no shuffle so far....
ill let you know how it goes once i rewire this fuel pump and add some more boost :P
what mods do you have?
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4474015
ill let you know how it goes once i rewire this fuel pump and add some more boost :/
hey, custom made dumps, custom made inlet (prob half the problem there!) injectors, pump, G4 link, profect b, etc etc running 18lbs 310 RWKW, stock internals, cranking boost to 20lbs soon.........
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4474157
Stock GTR bov's leak?
Yes
@ Idle they open and this helps avoid the comp surge.
same as the stock rubber piping etc etc.
Nissan made the RB26 setup perfectly in that respect. You have issues only when you go hard pipe kits, take off the stock BOV setup etc etc.
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4474261
I have -5s, HKS hard pipe kit + Drag Cooler, standard exhaust and inlet manifolds, 20psi, NO BOV, NO SHUFFLE.
Many people have recently had this problem, its related to the turbo intakes, BOVs, and a few other things I cant remember.
Id be looking at your inlet. Its the only thing different.
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475369
heres my inlet, it would be a pitty to scrap it.
any ideas ?
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475848
i have stock intake with pods stock dumps stock bovs stock cooler and air flow meters
my guess would be its your bovs... are they adj?
maybe try differnt setting harder or softer?
yes they are adjustable, my mechanic said he would try a softer spring.......
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475857
What R31 Nismoid and femno said :banana:
I have the same setup and no shuffle either.
As nice as it looks, I'd scrap it and go the standard bov's too.
dam i couldnt bring myself to scrap it, i didnt ask my mechanic to build it like that, but thats what he did, i dont want to through more money away too, might just get that BOV done, then live with the noise, just would like to here those ol' -5's spool up, rather then 'thomas the tank engine' on crack
cheers robbie
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475903
i get the same issues with my setup to the cchh chh chhh
i have std rebuilt turbos w steel wheel on ss manifolds, full hard pipe kit and no bov and pfc with afm just shy of 300kw but i recon its the manifolds not being tuned lengths or the hard piping not being the same length from turbos to intercooler. what i was going to do is run a 2 into 1 intercooler and make the pipe lengths the same from the turbos to the intercooler?
what do you guys recon? and im not giving up the the hard piping kit lol
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4475950
nice intake mate!
leave it and try the stock bovs first
hey thanks for that,
yeah going to try a softer spring first on the HKS BOV, then will prob leave it at that, may go back to stock if i ever have anymore spare coin :)
https://www.sau.com.au/forums/topic/260820-26-5s/#findComment-4477639
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
