  • Replies 94
Can someone let me know if there is a price diff between ISO and IS Copper....
Is that to say, if you drive to the snow, once, your car will die?
I occasionally visit skiing resorts....
The ISO kit comes with a valve that you open when the temperature is really cold (but subsequently reduces the benefit of the ISO spacer). It certainly won't kill you car. The main difference is the copper kit doesn't need this valve.
Unless you live in the snow I wouldn't worry about it.
The Motordyne has consistently better reviews, especially the ISO version.
I read that although skunk2 may be easier to install but skunk2 spacer is 5/8" instead of MD which is available in 5/16" or 1/2".
since the skunk2 is higher than 1/2" with the engine cover on it actually rubs the bonnet a little bit... fine if you want to leave the engine cover off but you may get signs of scrubbings on your plastic engine cover.
So to make sure i understand correctly rs73, after the install of the plenum, skun2 or MD, you will be able to place the cover on, but it will scrub?
Or is only an issue with the Skunk2?
I'd like to keep the cover.... but if the trade off is HP, happy to rid it.
The reason I'm going with the ISO Copper version is that it does all the things that the ISO thermal version does but does not need the CCV. Instead it has a copper plating to install on the throttle body. The CCV requires you to cut one of your engine lines to install and if you are going into snowy conditions you need to open the value to let hot air into the throttle body so it doesn't freeze. The copper version with is install and forget. Also means it can be fully removed without leaving any trace behind.
EDIT:
How important is it to install the ccv. i live in an area where it doesn't get that cold. should i install it and leave it closed?
Copper Iso Thermal is a premium set and forget component that can be used in place of the Coolant Control Valve (CCV). It doesn't matter how hot or cold the weather is, you don't have to adjust a valve based on the season or ambient temperatures. Install it and the throttle body remains heated while the plenum continues to remain thermally isolated. Keeping the throttle body heated prevents ice formation on the throttle body butterfly valve when driving in cold weather. If it snows or gets really cold in your area, use the Copper Iso Thermal so your engine can take full advantage of the cold air you are driving in.
Its not necessary to install the CCV but it is better if you do. Iso Thermal does not make HP but it does prevent the loss of it. Its good for about 1-2 HP by preventing excessive plenum heat soak as your engine becomes hot. And yes, you will generally leave the CCV closed. Iso Thermal or Copper Iso Thermal is beneficial no matter how hot or cold it gets in your area.
Edited by Aust350z
Updated List - please contact me if you haven't already.
Melbourne Group Buy @ $375ish - Pick up from maxw3l
1. me - ISO [confirmed]
2. dannyw (SAU) - ISO [confirmed]
3. db350z (350Z - pw350gt on SAU) - ISO [awaiting details]
4. Vai350Z (350Z) - Basic [awaiting details]
5. Aust350Z (350Z) - ISO Copper [confirmed]
6. SkEdY (350Z) - Basic [confirmed]
7. 3fifty (350Z) - ISO Copper [awaiting details]
8. NoImagination (SAU) - ISO [awaiting details]
9. ZTRACK (350Z) - Basic [awaiting details]
Sydney Group Buy @ $375ish - pickup from ???
1. BEE (350Z) - Basic [confirmed]
2. dkc64 (350Z) - ISO Copper [awaiting details]
3. g33k (SAU) - ISO Copper [awaiting details]
4. ??
5. ??
I really want one of these but I cannot see anywhere, other than the manufacturers website, a before and after dyno run. If anyone can show me a 10-12 horse power gain, I'd be in
Cheers
Geoff
lolz.. the group buy is going to end VERY soon, payment are being gathered and order will be put soon, i think..
IF THERE IS really a 10horse power gain, i m guessing some ecu mod on it..
as usual, any mod to reach its full potential, ecu has to be mod/tuned..
anyone can correct me if i m wrong, coz i just started learning all these stuff as well..
I've read a few threads which say otherwise, but cbf digging them up. By most accounts, this is acknowledged as one of the best n/a mods for a 350z/v35.
Anyway we've got enough takers, so up to you.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
