I currently have a 92 gtst for sale it has :
- Rb20 bout 140,000 kms and chassis has done bout 200,000
- To4e with turbosmart external gate
- Tein coilovers and adjustable castor rods
- 19 inch XIX wheels with brand new tires
- Gtr front bar with genuine reo support bar with a few cracks in the lower lip
- type m side skirts and rear pods
- re-mapped ecu done in japan not sure who by
- alpine cd player withe jensen 6*9s in the rear and jl splits in the front , 2 mtx amps and a focal sub
- 1000s of dollars worth of receipts
- kaaz 2 way
- front and rear strut brace
- Retuned and mapped a few days ago by geoff from speedlab it made a safe 219.9 on 15psi in can do more but needs injectors and afm
and many more mods pics below and i have more pics on my phone so if interested i can send pics of engine bay..
Chasing round $15,000 ono or trades.
http://img27.imageshack.us/gal.php?g=l6bfa...f4fcc998f96.jpg
contact 0432075410 or pm
kyall
https://www.sau.com.au/forums/topic/261142-fs-burgundy-gtst/
  • Replies 110
Posted Images
It also has fmic, full 3inch zaust from turbo back with custom dump pipe, 33 lower control arms, slotted rotors all round with near new brake pads, exedy hd cluth installed 1000kms ago, replaced crank seal and 2 cam shaft seals bout 500kms ago. any1 who buys this car will be pleased
mainly looking for cash but dependin if the trade is right preferbly turbo and nissan :( and yeah i was for sale in oct last year i think it was advertised on ns but since then i have doen the turbo conversion and spent alot of money on it mech wise like brand new radiator and camshaft/crank seals i use to drive this every day and its such a reliable car so who ever buys this will be pleased
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
