Brand new dual compound tyres goign on the bike = col happy in the pants... :rofl:
i got rid of that rash too josh, little bit of metho and some jim beam...
rub jim beam on your balls and the metho is to drink to help as the bourbon burns your shaved pubes...
morning bishes
anybody want to bring me some breakfast?
fridge is empty and too hung over to drive at the moment
this
ouch
Oh stupid me . . . I was doing it the other way round !
:rofl:
Does anyone know where to buy 3m branded Di-Noc carbon fibre vinyl in our area? Dont really wanna buy it from 3m directly....
morning bishes
not bringing you breakfast... but... speaking of driving. Did you fix your intercooler* bracket yet?
*Brandon: IN TA COOLAH. NOT Oil cooler. It does the green stuff, not the brown stuff.
Shotty not
fucking...
STOP RAPING ENGLISH!
The term SHOTGUN means that you wish to accompany the person doing said acticity. Saying "shotty not" means you're going to stand next to the person who's not doing it... it doesn't mean you're actually out of doing it yourself. The term SHOTTY NOT makes no sense at all, and it should be illegal to ever utter it (except for purposes of my explanation).
If you don't want to do something you simply say "Not me" OR "Dibs on not".
"Shotty Not" is just another prime example of Australia bending the english language over the counter and aiming for penentration.
now... don't make me slap you like a bitch ;)
P.S I think that dude in the photo is now one of my heros :rofl:
Edited by Isola
not yet. debating braving the sun and going outside, but still a bit seedy and dehydrated, so thinking of putting it off until tomorrow.
going to the coast shortly for a few more drinks, so not even sure if it will get done tomorrow.
FOUND SOME MOTHERFARKEN PRINGLES IN THE BACK OF THE CUPBOARD!!!!!!!!!
WEEE HAAAAA
i was starting to contemplate eating the cat (no eating pussy jokes please)
f**king...
Shotty not reading any more of your posts :cool:
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
