Don't listen to him Andy its good.
OH! I forgot!! The fried rice isn't even fried! It's the same glue boiled rice they dish up with other crap, but they tossed some veges (95% eschalot, 5% re hydrated peas) and egg in it. Fucking fail.
Edited by Isola
and designed by Renault.
i feel the need to point out that the VQ is in fact a NISSAN engine
just because renault use it for a few of their cars doesn't mean they designed it
clarkson has a lot to answer for with that one :cool:
Whats next? Holden designed the RB30?
Edited by Smity42
Anyone know a decent mechanic that can give me a curtosey car while they service mine?
surely there is a "i will service your ....." joke in there somewhere
i just can't think of one. i think i am getting less funny as i get older
Damn you all and your two less doors and damn your clutches as well!
I was typing and didnt realise that i originally wrote "cl1t5 as well"
NCIS is good and distracting.
Edited by Tony350
Evening gents
*tips hat*
*realises he needs to wear more hats, so that he may tip them more frequently*
Edited by mosquitocoils
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
