I burnt my pipe last night, if that counts?
In other news,
I was gonna come out last thursday but you know, not driving a riceline and all I would feel left out. Plus, I don't have a hat.
Edited by hylian
Nice nice.
Burnt your fingers yet?
If you burn your fingers your doing it wrong
*twirls pipe*
im soo getting my hat on on thursday
Flat cap ?
Depends on what type :bunny:
Dont worry about not having a riceline.
Geez, i drive a maxima-wannabe. Its not a maxima but isola enjoys arguing that it is.
Get a hat though. And if you can a pipe.
Come out anyway. Jason and I are both big Ford fans. You can hang with us :bunny:
+1
As for type... a genwine old school corn pipe... only the best tobaccerrr for this ollle farmer
Morning Mangs
Keen for hat tipping, keen for pipe (that's what she said)
OMFG I JUST CLICKED THAT 'Kittens in tiny hats' LINK WITHOUT REALISING IT WAS YOUTUBE AND IT WORKED!!! WTFONEONEONEBARBEQUE
Need to start bringing headphones to work I think :D
your at your desk at work at 7:39am
By 7:15 normally. It's by choice though, I do it so my trips to and from work are half an hour not an hour.
sucks to be you
I was going to say no, because I get to go home at 3:15, but then I read this:
ill get to mine around 10, and be home by 3... :D
What do you do btw?
Blocked website at work hey?
Not at mine. I can watch as much p*rn as I like.
granted I work from home though :)
Pootube used to be blocked, but they upgraded the filters recently and it must have slipped through.
Massive fail though, I just clicked on a thread in wasteland and got a big "DENIED! ADULT MATERIAL PRON ETC YOU HAVE BEEN NAUGHTY!!!!" message and now it seems the whole of SAU has been blocked :(
Now I have to use this sh*t slow connection I have h4xed to bypass the filters.
The work from home option is sounding good, I now can't access SAU or my personal email without h4xing, plus I have sh*t small desk. I should be able to a fair bit of work from home soon. At the moment though, I don't have any work suitable for taking offsite :(
What is it that you do that you get to work from home?
account manager
work in wholesale with the major CE retailers and FMCG retailers...
basically been in sales now for 11 years...
Eat a bagel, like a boss... send some fax's, like a boss... etc etc
spose i better go iron a shirt and go to work...
need to stop by the bank and post office etc on the way... might take an hour...
also feel like a HJ's brekkie wrap for some strange reason today... ummmmm
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
