then you sir are doing it wrong
you might also be visually retarded
I don't get it. At all.
neither....
This. Shes alright but I think I could list at least 57 other chicks from the interwebs I would rather fap to.
Oh and Morning mangs.
neither....
+1...
I like hot chicks. Just saying.
MORNINGGGGGG
I think either Saturday night or Sunday day. I'm easy either way.
Either works, as long as we are back in time for the cricket on Sunday (6:30 game time)...
That is a pretty big c...
That's what she said.
Your opinion has been noted previously, and duly disregarded.
Shut the fuck up cunts.
You're throwing off my rhythm.
Too much sharing...
page needs molly quoted to contine fap session.
Good. More for me and Martin to spit roast :D
K. Go.
Morning!
Morning
work
gay
the end
touche. Work is lame. 10 days till I finish at the Gold Coast.
What building you going to be at here?
morning bishes.
happy birthday for yesterday Jeremy
happy birthday for today Jason
Morning
+11ty
+11ty
So many birthdays... we should hook up a big kick arse November birthday party.
K. Go.
Day run is probably best. My lights have been f**king up again turning on and off randomly. Need to do another bodgey fix on them.
I will address the second part of your post when I get home lol.
Morning!
Morning
+11ty
+11ty
Keen for birthday party.
KK. Better make it pretty early.
I was keen to fire up my epic HIDs for night run though. Thristian still owes me a night run so I'll wait for that...
Weak.
Birthday party at the 'boomba? No need to hire strippers...
:D
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
