new forum blows goats, in other news i got no work on at the moment so im updating the lotus systems, which means i have no restrictions on the internet....
callvote stones corner thursday night?
he must have the worst record for converting 50s in to 100s of all time for a top order batsman
He'd go close that's for sure. You said it yourself though, he really should be a middle order batsman.
Monday flew by today.
As Christmas nears, so does my load of work increase.
In other news, my boss, and his boss just quit on Friday.
Should be an interesting new year. Might try to get me one of these vacant positions.
my work has gone crazy before christmas this year too! Normally it dies right down. Go for one of the boss jobs Miso! What is it that you do?
Oh i see, thats ok then. I just thought it was a slack day in here, i normally don't get time to post on here during working hours unless i am working on lotus.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
