In Townsville yet again, bur i'm planning on making an appearance.
Been thinking about somewhere we can meet. How girly are people about not being able to see the cars??
I went to stones corner baskinds last night and got an epic tub, so no need for me to go out tonight! Try the gingerbread flavour, its amazing
I might be there tonight.
Depends what time my evening appointment finishes.
Well I'm not going to drive all that way (be it CH/Stones Corner/Greenslopes/whatever) on the strength of a couple of maybes. Anyone else going?
IDGAF. As long as it seems to be a reasonably safe parking spot, I don't care. Others seem to though...
Just saying it cause i can, U2 is the shittest band, Bono is a cock, and the edge is a shit guitarist, all of his guitar work sounds the same. Plus Bono can't sing for crap live.
Bring on real talent, The eagles are next week
Morning Mangs,
Got attacked by one of those spiders with health bars last night. Lucky I don't have a handgun or I would have put a bullet in the thing. It was that big, Dan wouldn't even be able to miss it.
Greenslopes was pretty decent. Would visit again.
I'm going to have to bring my own chair if we keep going there, but other than that it wasn't bad. I will miss Grace^2 and Morgan though.
Also I would like to point out that the store is actually "Baskin Robbins Stones Corner": http://www.baskinrobbins.com.au/stores.php?state=qld
I'm not saying that Stones Corner is a suburb, but there is no rule that says they have to name their store after a suburb either.
Brandon, i couldn't resist flaming those flat faced lmgts :P
LolWut?
Hmm, should have read this before heading out. No ch love.
On a side note, new forums format is a heap better on the I phone
iPhail :down:
^^^^ This man speaks the truth
That's what she said.
Zombie survival.
End.
Edited by Smity42
Usually ALL the tables there are free and we all used to sit on the rails too lol
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
