Hmmm $800 + $80 + optional high pressure actuator (what pressure?) + $30 shipping...
That sounds pretty nice. What kinds of pressures do they generally run through high flows? They steel-wheel them don't they?
The high pressure actuators I believe are 16psi. Pretty sure the turbos can handle 25psi.
Nice. What are stock RB25 internals good for before they go boom? Somewhere around 300kw from memory? But that could be wrong, and I dunno how that translates to boost pressure
I'll do a scouting run whenever. I'm back in work on the 4th though and I'm going to wet n wild tomorrow. I can be nav aswell if it is a 31 only cruise.
Well, we'll see if we get an opportunity before the 4th...
Will put you down for nav duties.
Anyone decided what's going on for new years? If nobody else has anything on I'll probably just go home n bring in the new year with the family. If anyone is keen you're welcome out in the boomba.
Keen do to something... nothing planned yet.
Will your sister be there? :bunny:
yep. You basically have 2 options.
etc...
Thanks Dude! Good info. Will re-read and check into it later.
Anyone got some coin for me to borrow???
I can lend you a fiver...
One eyed Dirty-hwan owner........
Will probably go for the Hypergear highflow cause it's cheap ;-)
Bit 'spensive really. Anything cheaper?
:P
next few days are shit, funeral & woodford folkie for new years... sometime maybe the week before your proposed run i could be down
as in next week, or the week after? I'm back at work on the 10th...
This sucks. What turbo is on there at the moment? And what did you do to it!! lol
Nothing, I swear! Dan said it sounded like it was dying before he left. I said 'meh'. It sounds a hell of a lot worse now...
That's what she said.
Stop driving it till you sort a Turb Smitz, Last thing you want is a turbo shatting through your engine. Believe me it gets a whole lot more expensive when that happens.
Hey mangs missed out tonight due to wet n wild. Sunburnt and my feet are killing me, it was a good day out though.
NYE plans, come out to the boomba and have a BBQ n play some beer pong. Whoever is keen let me know so i can sort out food n shit. Plenty of room to crash if you wanna bring a swag or just pass out on a couch somewhere. I'll text round the address to everyone.
Sunburnt
Silly Ranga
Hell keen for Colin's Sister and Friends New Years BBQ. Want me to bring a barina to destroy? I'll need a lift home though. If not, anyone else from the northside going we should carpool or something.
Just saw Geoff manging it up on Gold Coast highway. He didn't wave back :(
Aww bugger :(
Where were you on the GC? I didn't see you... the gf probably had my attention.
Edited by GTTG
You picked the best day for it this entire year!
Also: Just discovered I won lotto, yay :)
Div 5, $26 :(.
Spent $21.70 on the ticket + $8.80 in the work syndicate. You do the maths :( :( :(
better than my wife loosing both her grandparents in the last 4 days... :(
Sorry to hear Col, seems it has not been a happy holiday for a couple of people :(
What's doing gentlemen ?
About to go to jaycar to get shit to fix my dodgy speedo
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
