good german guys, any actual german here or is it all googled? if so, well done.
I googled a word or two but the rest was legit *thristian finger snap*
But yeah, been 11 years since I've done german, wouldnt not be able to hold anything like a conversation...
This just in
And no it wasn't anything to do with me. Twas the gas peoples
Likely story...
haha!! The brown stains. Most of them are all flat-cappers. The Aussie non-descript, surfie-boarder-Xtreme-sports kinda gumby.
You know, Boardies, singlets, southern cross tatoos, aussie pride stickers, flat brimmed Ken Block caps, 4ltr cans of monster drinks, bustin' arse in a Falcadoluxeo with altezza tails, G-Unit stickers, skids rims and 4" lowering blocks with a tougher-than-2Pac look on their pippled face with their fat 18yo preggers g/f with their 3 other kids in tow with 1 from a 'prvios relasionschip'.... all 10th grade dropouts...
Good old Stains. Some of society's finest right there.
  • Like 1
  • Nope 1
my 13 year old nephew whould fkn love those shirts with skidz and boobz on em.
No better reason to pre-order for Christmas!
http://www.hardtunedstore.com
  • Like 1
  • Nope 4
good work then :) I am German...grew up speaking it. but when it comes to reading and writing it. im a bit slow......ayyyee.
Short for Special Ed.
Ah I see. Haven't heard that before, we must roll in different circles.
It's also funny coming from a user(Isola) who bought a GTS4 because they couldn't afford a real GTR.
I guess they also missed the bit where I posted in italics to denote sarcasm + included a giant troll pic to illude to the fact my reply was completely taking the piss, gg sped :thumbsup:
  • Like 1
  • Nope 2
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
