Could have been worse: They could have given you an iPhail.
Only the best for me, I openly bought an iPhone (I actually was given it for free, perks of being with a telco since they started) so I've got the best of both worlds.
I'm actually iphailing right now since theres an IPB app, I can SAU on the potty.
The only people I hear complaining about iPhones are people that dont use them.
One of the things I hate about the iPhone is the car sales app. I spend a lot of time looking at gtr's
LOL there's a car sales app? Does it do anything that the website doesn't?
I tend not to bother with apps when there is a website doing the same thing. Like the SAU forum for example. The mobile version of that works really well.
I love Apple, my Iphone 4 went for a swim in coke still worked but had dots under the screen where the liquid got in. cleaned as much as i could with electrical contact cleaner.
Then took it back to apple and complained the Home button wouldn't work, they replaced the handset on the spot :devil:
Have an iphone 3gs. was reasonably happy with it till about a month ago. Now it just refuses to be a phone. Randomly won't let me make phonecalls for five or so minutes at a time, and then just randomly works. Randomly won't accept phone calls. Driving me farken nuts.
Just think how good christmas will be when you're 65.
+1
I never begrudge a contribution to my super :)I am paying 6.5% into my super for epic super funtime retirement
+1
Mate of mine lost 8 years worth of super at 65k a year salary.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
