John Q4 Brera aren't too bad, heavy and slow i think though other people have different thoughts, pretty much the engine in it is what you guys call the SIDI i think. It uses the GM global V6 bottom end with alfa's own design direct injection twin cam variator head, which holden then used.
Awesome, thanks for the info!
Was thinking of maybe looking at one, but maybe not now. SIDI engines are a terrible design from a working on it/modifying it perspective. Not much of an improvement on the Alloytech really.
Where at!...Your place ?
The late late show with Craig Ferguson, he has a robot skeleton as a side kick...
Its on the new "hello" channel at 10:30pm week night, very funny...
He says random stuff like "sex party" and "in your pants"...
[vid]
[/vid]
There's a gremlin living in the front drivers side of my car I think. Wheel bearing needed to be replaced there, the window actuator doesnt work there and doing a simple job like replacing my brake pads turned into an overnight stay due to losing a copper washer off the brake line causing fluid to go everywhere.
nice work. I say fix it enough to sell and buy a 31! haha.
Today while at indro, andy spotted me, and then i spotted twocents, he didn't see me, but i saw him coming out of the cinemas
Had a chick in tonight who was wearing a little black vest as a top. Only thing was that she didn't have it done up and had these little butterfly stickers over her nipples. So much win, especially when she was dancing at the bar ;)
Morning Mangs,
I like boobs.
Drove the 31 to work today. Much win and awesome. Must try to find time to call EFI today...
Joined SAU QLD forum and club !
Successful day !
I paid my monies but haven't heard back yet :(. Andy must be slacking...
Lowball club cruise = great success :thumbsup:
@Colin: Won't actually see you Thursday, will be in Melbourne town :D
Lowball cruise was great. Ah true mang. Definitely need to hit up the F1 next year.
Wash your colon, GTR
Yeah it's pretty filthy. Got this weekend off though so I'll wash it then.
Oh and Morning Mangs
I can ask John to put his pink bikini on and wash your car for you?
Where is young John these days? Doesn't post much anymore.
Edited by hylian
Thanks for driving me. :wub:
Missing, presumed employed.
We lost power this morning, good stuff for a power distribution company...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
