he was flailing the whipper snipper around like thor's hammer, whilst swearing in german and occasionally yelling in a strong accent "DON'T EVEN THINK ABOUT IT" sounding like Arnie gargling roof nails.
Sig'd.
Sig'd.
no more sammich quote?
two was too much to ask for :P
paid for fuel this morning. 163.9 is an all time high that I have paid for the litre. just over $80 to fill the golf, and I am pretty sure the 32 is nearly out.
I paid the same last night...mega gayness
in other news
can some one open this link http://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/190613_118765794865911_100001974734909_143505_436452_n.jpg
save the pic and upload it to this thread, work has all personal storage blocked and I am bored so I want to compare this dyno graph of -5 to my 2510s
sammich one vanished a while ago actually... it got too old :P
I have 3/4 a tank of stale fuel in the 31, should last until I get back from melbourne :). Will put fresh fuel in for the tune.
in other news
can some one open this link http://a2.sphotos.ak...05_436452_n.jpg
I saw that man, and Its a pretty nice power curve, but, I would say it's a little low. -5's are 720HP worth of turbo.
Interesting it makes 10- 15 more horse power every where until it pulled away right at the end. Running lots more boost though (about 7 psi more!)so that might have smothing to do with it.
Its probably not a terrible result for him, it was done at the same tuner as me and his dyno is a bit of a low reader...as evidenced by all the sad faces at the dyno day the club had there! lol
I think you'd be doing really well to get 600hp+ out of -5s. The highest I've seen is 430kwish which is about 560hpish? I want to see someone throw a set of those new efr turbos on a 26 or 26/30. Would be a bitch piping wise but I bet they would crank out some solid numbers with epic response.
yeah twins on a GTR never seem to be able to hit thier combined rating, mine are rated a 310hp each...but are no where near that, infact people are amazed that i made what I did at the boost level I am on so yeah my 620hp turbos are flat out making 450 at the engine
Yeah I don't think it's as simple as I have 2 x 400hp turbos so I should make 800hp. Either way -5s seem to be the go to turbo if you want 400kw and still keep the twins.
sadly there doesnt seem to a be a lot inbetween somthing for 300awkw like a GTSS/ -9/2510 or 400awkw like 2530/ -5...though it would seem like the 2530- -5 are quite capable of matching at least the 2510 for response so just running them at less boost could fill that gap
Yeah, Twins never hit their advertised theoretic and neither does a single, although it does come alot closer, there are always loses, heat,drive train etc etc.
Are you talking about mercury, I was there for that dyno day a couple of mates had their cars run up.
I made 431HP on R33 N1's on my 32 at ~17PSI I would like to make more then another 36HP with a few hundred horsepower more of turbo on board.
Not to take anything away from that result, because that thing would go like a bat out of hell !
My N1's are busted now (oil seals) so -5's will be going on and shooting for 400AWKW.
See how I go i guess.
Today I made Craig do work. Was lulz :cool:
Yes i did have to work hard for that lol. The strange thing is that you will get more $$ for that sale than i will lol.
400awkw seems to be on the really well sorted motors with all the fruit to back it up + running 25psi lol. Most results on the -5s are 340 - 380kwish and yeah the response is pretty good aswell. You could get -9s and run E85 and go for 350kw lol.
I think he is referring to EFI at Yatala. -5s will be sick.
just be sure to keep going back to the same dyno to measure differences
and don't be disappointed or disillusioned if the temps and humidity is different on different days
most dynos have compensation to power depending on weather conditions
to give you an example of how different dynos can read;
roughly same temps etc, just different brand/model dynos (GTST 33 GT30 @ 19psi);
Matt Spry = 312rwkw
Mercury = 336rwkw
Allstar = 301rwkw (with wheel spin)
Godzilla = 331rwlw
So it was impossible for me to tell how much power I was making as it depended on which dyno we used...
all i know is it was 300rwkw+ :D
Yeah i am considering E85 at some point. taking my boost up from 15psi and running E85 would get me pretty close to 350 as well i reckon!
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
