Quite possibly a little end bearing which is not as serious. I didn't get a chance to hear it to confirm but I will if I'm up there tomorrow
Thanks.
I've had my doubts on the quality of the rebuild that engine got for a while now...
On a more positive note, I did rub my nuts on the left rear quarter of your car for good luck today. Damn clean car mate, well done!
and I'm not joking, I actually rubbed them on your car.....well, through the shorts.....but damn that fabric is thin so I reckon it's the same
LOL. I'll make sure not to wash that qtr ever again ;).
Thanks though :D it's good to see SOMEONE around here can appreciate a 31 :thumbsup:
I'm suprised it's held together this long, built in a st lucia garage by a bunch of drunks, i wasn't even a qualified mechanic then
pfft, sif nobody appreciates it. that 31 is the reigning sau show and shine champion
:rofl2:
31's are all good IMO :D I think I saw yours the other day when I went to drop something off to Whitey... Is yours the white one?
dan, thats like a chick whos had a face lift and butt implants... do not like
if only she had a boob job, it would look great...
lol... Yeah def not something that i would drive but interesting none the less
I am just counting down till 1pm. Have a meeting, which is the only real bit of work I get to do today.
Until then, surfing the net, and playing on my iphone.
I'll take your shroom ;-)
If you do want it, I can probably grab it off Dave and bring it for you on Thursday. Save you a trip.
Still have shroom if you need it. ;)
haha yeah sounds similar to my day.. I do have tafe work I could be doing but Im not really in the mood :/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
