I bozzed in my pants, I bozzed in my pants.........I opened a window and a breeze blew in.......I bozzed in my pants, I bozzed in my pants.....
bwahahahahahahaahahah :thumbsup:
getting to work this morning requird a stop and rewater, but new hose fitted and seems to be functioning finerofl.gif
must get better wheels and tyres for next time!!!!
also are there gonna be pics up somewhere?
Edited by KRECHR
@John: GPS says I was doing a max of 190 :(. I don't think I trust it.
Also, you owe us some pictures ;)
that reminds me. I should look at Boz's one once I toss the screen back in. I bet it says the same if not higher.
Don't think I got it much past 170 or so down the main straight, will be curious to see what I actually hit. Was too busy looking at the track to pay attention to my speedo.
we will know on wed morn.. (hit reset on it as well ;) )
I watched your speedo max out and the rpms keep climbing. That last run down the straight felt like 210 to me.
I found out I don't have speed limiter cut on my car after my speedo hit 180 but I doubt I hit quite as high as 200. Didn't feel as fast as the pintara.
Pictures soon bro.
Can't trust a factory speedo anything past 100. Can't trust my speedo at all, its reads about 12% high at the best of times.
I would however be surprised if I was doing less than 210 in the sprint sessions. That run I took you on, that was probably 180-190 odd.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
