you back at home?
how's the neck?
trade you a fishtank and a big screen tv for your 33 :)
I'll see your fish tank and raise you a pocket bike with no engine.
Would be a pretty big job. n/a ceffy would have 4 stud hubs so would probably need to swap all the brakes and hubs out as well.
Yeah sounds like fun.
Ps I have a 4dr 33 to strip.
I say toss it all into the cefiro :)
that said if you need a hand stripping it , I'm up for it.
so lets get crackin on it. otherwise I want the engine harness and ECU off it :P
See what the insurers say, frikin old lady, f*#k my car up. It's a wonder you didn't here me scream when I got out of the car.
I'd be up for a stripping day...
But yeah, i hear you. Insurance doesn't cover the time spent getting a car just right, doing all the litle things that make it good to you.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
