posting for the sake of posting
don't want to go to bed, because want to extend my time awake away from work
Sad when it gets to that point isn't it ? lol.
so whats the latest with the wreck Jez? You getting it back? You putting its heart in the ceffy? Or as per usual is the insurer dicking you around and you have no idea yet?
Written off.
Inspector finished his p/work yesterday, waiting on claims dept to find out about payout, salvage and police report.
By the way things are going I'm thinking the police report will be the hold-up.
I just had KFC, and have a switch. A big fk off switch. Life is looking up.
Nuke switch good.
oh... and Pub lunch FTW
Written off.
Ring the cops CONSTANTLY about it, last time I had a claim in i rang after a few days and they said 'not done yet, we will call you' one month later I call them and get 'oh that was finished weeks ago its all good to go' gaylords
has 4 more red dots in it now. will probably have a couple pull levers as well.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
