From the other thread:
You've changed man. I don't know you anymore....
might go five doors yet.
This is the best thing you've said today.
NG, what's up with that?
Martin = manrags
I suspect the starter motor is going/gone.
It goes 'click' but doesn't try to spin. Its done it once before.
Will need to check the wiring is OK, and try hitting it with a hammer. I didn't have time to mess with it this morning.
Sounds like a problem with the AFM and CAS.... I'm just sayin.
Martin, where did you get your z32 ecu all wired up for Nistune? I could do it myself but i am not all too confident in my soldering skills...
I can offer up some assistance ;-)
ECU: Scott did it for me
AFM: I did it myself
This guy.... /\
He knows....
So,
Starter trigger wire is fine, because I can hear it throwing out.
Belting with a heavy breaker bar didn't help (no room to swing a hammer).
Voltage Readings look something like this
"ON"
Battery - 12V
Starter Feed Wire @ Battery - 12V
Starter Feed Wire @ Motor - 12V
Terminal on Motor - 12V
"START"
Battery - 11.6V
Starter Feed Wire @ Battery - 11.6V
Starter Feed Wire @ Motor - 11.6V
Terminal on Motor - 0V
Problem with the connection of the wire to the motor?
I put a jumper cable from the battery to the terminal on the motor, and she started fine.
Took the jumper cable off, and it wouldn't spin again. However, a few quick turns to "START" and she kicked into life again. Now starting no problems.
On the weekend I might try disconnecting the feed wire and hit it with contact cleaner then put it back on...
So,
"ON"
Battery - 12V
"START"
Battery - 11.6V
Check your earth connection to the battery as well. When that starter needs to draw like 60 amps or some shit, if you have bad connections, it won't be enough to throw it. Sometimes, also, adding the extra lead enables it to get past this point and throw anyway, even though the bad connection is the slip rings or solenoid.
I'd try cleaning earths and power cable first, then if it still plays up, pull the starter apart and just clean it out. 90% of the time it works every time :devil:
Right, now I'm gonna head home...I've spent enough bloody time at work today!
yep agree, sometimes a reading on a multi-meter for voltage wont tell you the condition of the connection under heavy load...
start with the basics Martin, your on the right track...
Oh and Dan, 63.8 % of all statistics are made up on the spot... ;)
I'd blame me for picking your brain for so long this afternoon, sorry about that.
Better than picking my bum. No need to apologise, I'm very grateful to have you as a customer.....and even moreso one that doesn't pick my bum
whinge whinge whinge. I am still working. Got another few hours left too.
:P
i seem to remember telling martin to check the wiring to and from his starter motor the other weekend when it broke down on him.
I heard it throwing this morning but no starter turning, if i was more aleart i would have offered some assistance.
In other news i worked back late tonight, need cash to throw around for my NZ trip in a couple weeks, got home at 11:30 tonight though. :(
Morning Mangs,
TFIF
Check your earth connection to the battery as well. When that starter needs to draw like 60 amps or some sh*t, if you have bad connections, it won't be enough to throw it. Sometimes, also, adding the extra lead enables it to get past this point and throw anyway, even though the bad connection is the slip rings or solenoid.
Good call, I'll clean the earth wire connections while i'm at it.
I'll be in the 10% that breaks it for sure :P. I have a spare starter somewhere, might just find it and swap it in.
Yeah I can't measure the current directly with a 10A multimeter, that's why I measured the voltage with the key to 'START'. At least then you can compare the voltage with load/no load.
That's what she said.
Maybe if you weren't up till 1:17am on a school night, you'd be more 'aleart' in the mornings ;)
38.2% of people wouldn't believe that
true true...
Yep, thats the way. You have narrowed down the area of the problem.
Now to clean and inspect. Then wash my car.
LOL so helpful ;) If after checking all the wiring may be worth checking the bearing in the tip of the starter motor. My one on the corolla had a tendancy to keep wearing in an oval shape; gripping the motor when it threw out.
martin, just hitch a horse to it and treat it the way a pintara is meant to roll :P
I doubt a horse would be able to pull the heavy-a*se piece of sh*t.
A pull-starter might be in order though...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
