Very quiet today here at work so did some car surfing and saw this on carsales. http://www.carsales....mode%20matchany That is a whole heap of engineering and how the hell does the bonnet close flush!
Edited by Kiwibob
Craig fails at the Internet :P
Yup i suck!!! Damn Cold day is cold!
Perfect weather for a good day at Lakeside tommorrow... oh wait it has been postponed.
You still going? I don't know if I cba anymore.
By the way... do you still know anyone in sales at Norris?
yea i do. which branch?
Yo Mang's, what does a mines ecu let you do?
not a lot. its set for the car it was on. I have one for mine.
Webber P1... discuss awesomeness
Didnt vettel look pissed that webber was fastest.!
they rekon with the blown exhaust being taken off the redbull it means webber will now be better. I sure hope so.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
