It does mean you can do whatever you want to your car and never have to worry about defects.
It also means you can't just drive your car on the road whenever you like >_<
I miss it, bad :(
I miss it, bad :(
Sif worry bout defects. Just have nice hair. :thumbsup:
cops that dont write tickets, maybe they had an afternoon beer already and just wanted to go home?
There was 2 cops (well 3 actually, one rocked up in a second car halfway through, but it seems he just wanted to watch...). One was a guy, and he really didn't want to let me get off scott free. The other was a chick and she just wanted to give me a warning. Clearly she was hot for me ;). They seemed to settle on giving me a defect notice but no demerit notice, but then couldn't find the book so just let me go. The dude was clearly unhappy about it though.
Tirerack KU31
Like $105 on tirerack.
+Postage yeah? They're only ~$120 odd locally, so I don't reckon they'd be much cheaper. And I don't have to wait for them to come from overseas. I may be a 31 owner but I'm not that tight.
I got hassled by the cops for my tyres
my ride height, cage, steering wheel, blow off valve, rim width and lack of h pattern were mentioned too
he did say I had great hair, but still gave me a $200 fine.
Ghey
LOL.
To be fair though, you do have great hair
Truth.
less than 100mm ground clearance
I'm surprised actually, mine never seems to get checked for ground clearance.
Said solution involves driving around in patrol as daily. Chicks hate that. >_<
Werd.
I miss it, bad :(
That's why you need a fun car, and a daily which is also fun :thumbsup:
...shame it's such an expensive exercise :(
But that didn't work apparently...
thats because try as he might the f**king idiot couldnt find anything else on his laminated cheat sheet to get me for
On a more pleasing note it would appear they have realised the stupidity of dragging people through court for a bov. Quite a few members have been nabbed lately but only given a minor defect notice.
That's why I carried a cheat sheet killer under my passenger seat.
current code of practice printed in A5 format and mods brochure.......for the 'On the go' arguer who likes to keep it compact
I spoke to a copper friend of mine about that....the judges were really beginning to resent having these types of offences go past them and started giving favourable outcomes to the 'hoons'
LOL, probably would have been the same for me if my tyres weren't bald at the edges.
There's no way that should be anything other than a minor defect. Win.
Spotted: Thristan at Geebung Commonwealth ;)
I didn't think drifters had any use for banks :P
I also have my own mini trundle wheel and tyre depth gauge.
I like it!
Obviously a Holden/Ford fan who hates "riceburners"
Or just trying to meet his quota? Who knows.
Good to see there's some common sense in the system somewhere.
What size?
Doesn't matter Dan, thanks tho
bit late now and I dont have a spare rim anyways...
guess ill see how shes goes down the line with a cold tyre first...
So it is friday nite. i am meant to leave in 10 mins but due to a lovely HSV function i am here till 9pm. So i get to sit here and listen to some lovely old and overweight men talk about how great their HSV's are. AND the kicker..... I dont get paid to do it,,, hmmm Why me.. did i do something wrong in a past life? :worship:
Edited by Kiwibob
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
