your car looks cool with my spare wheel lol
hehe!!
your thing is broke. it is what we think - part will take me 3-4days to organise. ready for you to gravb or wander over later and grab the keys off the front counter.
Another week as an unemployed bum begins :)
Stock market makes me :( however, thinkin I might cash it all out an buy something that won't depreciate so badly, like a GT-R :P
Hmmm sounds like a plan.
i cant believe how quiet the last few days have been. i spoke to 2 people yesterday and 1 today, this is going to fustrate me lol
All i seem to be doing is looking at things i want to spend my tax cheque on. BAD move
Chuck it into shares, good time to buy right now i think.As someone said though "chuck it into shares and then don't look at the stock market for at least 6 months"
screw shares, get gold! :P
My Brother in law and I bought gold for around $1000 an ounce in feb 09. Now sitting somewhere around $1600 :).
Though long term shares at this point would work too, and by the time they are turning profit you will have had them long enough to reduce the tax you will pay on them at sale time.
now would be a bad, bad time to cash it in unless you need it to avoid starvation.
what happened at the fox?
I mst have missed the story
pm if you wish, but i need to know these things. i don't get out much, and black ops is just not cutting it anymore
Particularly now that the general instability has gone (well, give it a few weeks for this to blow over) i think you'll find gold is actually a pretty bad option. Though you've done well in the last few years, on average it doesn't seem to go up as much as the share market does, i think.Or something. i'm not a professional.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
