Not sure if hilarious or in bad taste... Both?
its been a month or more...
F*ck only just made the connection... definitely overtired :(
yeah i thought your response was a bit sorta casual...
PS> Split my head open today in the roof fitting some down lights, hit a noggin with my noggin... ouchies...
Likes this, wait what.
Mangs.
Anybody keen to come for a drive to the jdmstyling meet tomorrow at sunnybank?
Nice cars out there, but don't feel like having to meet new people and be all social and shit
Here you go Scott, Bang bang video's of the Pintara.
is that your wagon?
I drove past it a few weeks ago and noticed it because of the stickers on the side.
Didn't realise that was your new 31. What's happening with the 33?
Edited by PWND
Mangs.
id be keen but im not goin to another one of those till i get my new wheels!!! ps make sure your early or you wont get a park!
is that your wagon?
Yea, it did have stickers on the side last week, they have been removed since.
Have had the 31 for about a year now i think, $300 of ebay and I've spent around 1k on it thats a sound system, new clutch and the ignition system cheap motoring ftw.
Bought it to putt around while the 33 was being stripped, still have both cars
But your kingdom is a 31 and a half finished Alfa... Not sure if that's worth a day off :P
Then again I can't really talk, I have a non working 34 with some electrical fault to deal with.
Speaking of days off, any luck on the job front?
Mangs.
if I can get clear of all these cars - yes I will attend in the subaru. call me if you are going.
if I can get a spare second I'll come past.
Where and when are you guys rocking up to sunnybank?
Haven't met any SAU members since SCC08 haha...
But since then... got married...
I will def be going, so if you are free, see you there. Will send you a text shortly
It starts at 7pm. There are a few of us meeting at Richlands train station at 6pm, leaving at 6:15pm if you are keen.
What. A. Sucker.
:P
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
