It starts at 7pm. There are a few of us meeting at Richlands train station at 6pm, leaving at 6:15pm if you are keen.
Do you do this every week? I'd be keen for next Monday. Will be keen to see pwnd up close - Sounded great last time
It's alive!
I know :P
richie,
its a once a month thing. two nandos operators run it in conjunction with a web forum
PWND has been changed a bit. I put my hands on it about 2 months ago.
I'm keen to come for the next one, as long as I remember - Just I wasn't free until 8pm tonight :(
the one tonight was a monthly. there was a few hundred cars out there. bit hectic
if you are free thursdays, there is ice cream out at baskins. that's a weekly thing
can cruise down together if you are travelling from forest lake
I have a mate in Forest Lake with an R34 that would probably like to come as well. Might be able to get the misses to come if there is icecream haha
What time do you head out?
You guys having all your meets on the days I train :(
most of the guys are there 7ish onwards. I usually leave forest lake just after 7
Very cool - I could do that. I'll ask my mate if that's okay - Hes on these forums also 'fastjetjockey', drives a 34
Stopped by Forest Lake subway earlier today. Police walked over and had a look at the car - He said 'wish we had these as undercover cop cars'
farking lol
Forest Lake, re-pre-zent....
:ph34r:
Which Baskin is it? Mt Omm/Riverhills?
chapel hill. 10 min drive down centenary.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
