Here is your non work safe pick me up :-)
http://iwantpix.com/9291/angie-varona/
fark...I would hit that with Poland!
She has a funny thumb like Megan
You saw her thumb? Are you feeling ok Jez?
Morning All.
Can any of you samsung galaxy people answer a question i have of the battery?
Phone is truly awesome but the battery is, how do i put it, crap! i am lucky to get a full day out of it and im not using it all that much. Is there a fix or do i just put up with it?
Cheerz.
Morning All.
Cheerz.
Same here. I have fixed it by buying another charger for work and a car charger. And Ta Da, no more battery issues.
lol yea i think i will do that. i use the usb cord atm to charge it at work.
Make sure you don't have your wireless constantly turned on - This is a massive battery drain. Only turn it on when you plan on using it.
I onlyy turn it on when im at home and connected there. Otherwise it is off.
Dont get me wrong, it is an awesome phone and i am more than happy to put up with a short battery life but just wanted to make sure it was normal.
Get the battery doctor app, do a full cycle charge and bingo should last you the day no worries.
Mine stopped charging all together, off for a warranty fix for me!
stopped charging cause of water?????
I normally can get 2 days use from my galaxy S2 are you constantly using the net?
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
