hey guys im rather new on here, and im new to brizzy to haha.
anyways ive not long gotten hold of an r33 4 door, after sellin my n13 exa and going thro a few other cars haha.. neways hope to catch some of u guys round
Hey Scott
Nice work - Did you spray that in your garage where it sits in the last photo?
Thanks Richie. Yes I did spray it where it sat. It wasn't moving anywhere!
Happy Birthday to the Ranga Manga!
He wont understand unless you call him ginger minge.
Its birthday time of the year this year... now and november
didn't it do that last month too?
something, something, every 28 days....
That was the starter motor though.
Starter motor is spinning fine now, just no love :(.
No love for the box or from the box?? see above statement about 28 days...
shoulda bought a R32 GTR.
Yeah bitch the boot is finally on the other foot! :P
size 10 steel cap?
Bumper looks great Scott
Done with work for the day.
Will try to sneak in a nap, but I dont know how successful I will be
Thanks fella. Sleep is for the well rested.
Is it Colins birthday?
Didnt he just have one last year?
Apparently, for every year we have, it's like 7 years to him. Buggered if I know how the Day walker still looks like he's 21....wait 22??
more of a "happy new years/valentines, take me now, no time to bother with anything! *9 months later* well shit"
I wouldn't be surprised to see a spike in the birth rate for the next month or so. Nine months after the floods and all that. Only two things to do during mass blackouts when you can't go anywhere ;)
And you know that flood chicks get well wet.
Morning Mangs,
TFIT. May or may not be late tonight. Will be there at some stage though.
Feel free to come out to one of our thursday night meets @ baskin robbins chappel hill. 7:30 till 10ish.
You can make Jezza jealous with your 4 door :P.
Yes I did spray
That's what she said.
Only a ginger, can call another ginger ginger.
Both at that stage. The love is back now though. Yeah baby...
<3 the box.
I'm not going to touch that...
Thanks fella.
Daywalkers don't age, for they have no soul.
stick your head in t baskins on moggil rd chapel hill - may as well put a face to the tag :)
martin,
I may be out as well. rumor is there is a red commodore that likes to pick on noel. want to rectify that.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
