Sounds a bit harsh reading that back but having the day off does nothing for the guy or his family. If they wanted to show respect or help out they should have worked and donated an hour or 2 of their pay to the family to help them out. But like I said they're just looking for another day off after the melbourne cup.
Agree 100%. They loose a days pay, may as well organise it so they work and get paid 75% and the other 25% goes to the family. Would be worth at least several months pay to the family. Much better way to show respect.
When I was in my teens I worked for my dad as a sparky's apprentice. I had the weird position if seeing both the union and the employee sides of any dispute, made me dislike how unions operate, but I admire why they are trying to fight the good fight.
unions and lawyers, all tarred with the same brush. They would have you believe they are working for you but the pricks have their own agendas,
Do not believe the lies:
This clutch will not install itself, no matter how much encouragement you give it :(
mine has this same pic on the back......still sitting in the shelf downstairs.
Morning Mangs,
Have to work late tonight :(, so may be late for ike's cream.
When are you ever on time?
Guys ended up going back to work at 9:30 this morning after the union f**ked around for 3 hours lol.
haha no i wont but there is alot of helpful hints for other areas of your 'romantic' life!!
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
