can any of you guys draw ??
as in engineering drawing?
need a template measured and drawn.
how complex Chris?
I did graphics in grade 9 & 10 and have CAD software here at work, if it's not too hard I may be able to manage it.
R32 GTR tach panel - need to make a drawn copy of it and indicate what area needs to be clear for a 4.3" lcd to sit behind it.
doing a retro nismo display for my 32.
nah piece of piss in comparison to that. I will pull the cluster and take the relevant bit out of it. you can make the call off that.
Well, finally got the stag back after being without her for about 3 weeks. Received 2 A4 pages of work done and half a page of items replaced totaling $3795 (ouch). But from the tiny amount I've seen so far it running a million times better. Pretty well completely stock apart from pod filter and exhaust system. Now I just gotta pay that off, save some more to do the suspension, fix the VCT and a few other minor bits and pieces. Need more monies so I can get moaw power. Very happy so far though.
205.2HP @ 7.5PSI with at least another 80HP once VCT and small leaks fixed.
Edited by Grimi
Hi I'm new 2 the site and just wounderin where and when u's are meetin i wouldn't bringin out my r33 gtr!!!! Can anyone attend and do many people turn up????
if you are who I think - why haven't you popped up sooner..
Good online stores to buy shoes / shirts from. Looking to replace my now stolen Vans block letter shirt and need new shoes. Went to Chermside tonight, absolute nightmare. Now resorting to online shopping from now on.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
