sounds like you are making compliment to uq web servers :D
anyway.. cant wait for this :thumbsup:
http://www.uq.edu.au/orientation/index.html?page=90123
Miss market day.
Qut has nutin
I always consider the general ineptitude of UQ at most things it does from an organizational stand point to be proof of the old saying "those that can, do. Those that can't, teach."
Went through that list earlier today after looking at what UQ had to offer.
Going tomorrow for the Motorsport team meeting and see what free crap I can get.
Toga party, i'll definitely consider.
Need white sheets!
At least I'll be busy once uni starts :) not used to working only 25 hours a week. Lots of time to waste and no money to spend makes me a bored man.
Thats the shittest thing about uni, now I have lots of money and no time...how does one get lots of money and time??? >_<
I did have lots of money and no time. Now I've voluntarily reversed it to go back to uni :P
In answer to your question, to have lots of time and money you first need to pass through the working 16 hour days to make a fortune by the time you are 40 phase. Then you turn 40 and can cruise... That or sell drugs.
Start your own business early is the only way really. That or be born into it. Working 70+ hours a week still wont get me to where I'd like to be fast enough lol
New living arrangements all sorted. I was going to move into the place at Moorooka but god was all "Nah bro, move in with the hotties!" so I was all like "But it's too far away from work, not airconditioned and I don't get my own bathroom!" so god was all "Nah bro! You should totally do it!" and then he made it so my choices were removed from me.
God, you are a twisted son of a bitch but I love you :)
true, then you pay it all out in taxes and the gov't then wastes it on people that do not deserve it. born into it is a better option.
Nice little place for sale here :wacko:
For Sale
not bad. looks like an old live in CBA. stick a chiller in the vault and have an awsome fridge.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
