Who wants to do my stats analysis work for me? Base level stuff so we have to show all working instead of just plugging it into a nice big spreadsheet full of macros.
need a R32 cluster. dont care what version of the car just needs to be R32.
about to fix up someones expensive mistake and I need a second black gauge overlay..
need the whole black backing plate.
need to do big cruises more often.
my tank is still on about an 1/8 and im just about to hit the 500km mark :happy:. thats better than ive had for a while
Good luck finding a real 200ZR however. Weren't they rare as hens teeth?
Also, beyond rarity what did the ZR have over the ZX? I'd probably prefer the VG30 over an RB20
torque would be the difference from my point of view.
Boz - I really only bought it to save it from being wrecked... he wasn't going to keep it in one piece much longer. When your insurance is sorted out if you're interested, happy to talk :).
Also, C31 laurel, Y31 cima/cedric/gloria, A31 cefiro... I'm sure there is more :P
Chris - Sorry mate only just got your message. It's already here, and I don't really want to drive it until the rego is changed over. You're welcome to come round and have a look if you like, I should be home all arvo. I'll call you a bit later.
Wouldn't an RB20 have considerably less tourque than a VG30?
And Smity, buy them all ;) I shall then dub you Mr 31! And we shall talk when insurance gets sorted. If it ever gets sorted... I was promised an answer by 5pm Friday. No answer as yet...
Did some digging. From the factory the RB20DET had more or less the same power as the VG30ET (one or two HP difference) but 15nm more tourque. I guess the 4valves per cylinder and higher boost/addition of an intercooler really make all the difference.
Where have all the cheap S chassis cars gone? Can't find a turbo, manual S13/S14/180SX for under about $5-6k. Looking on Carsales, Nissan Silvia, Hard Tuned, Boost and here...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
