Who wants to do my stats analysis work for me? Base level stuff so we have to show all working instead of just plugging it into a nice big spreadsheet full of macros.
need a R32 cluster. dont care what version of the car just needs to be R32.
about to fix up someones expensive mistake and I need a second black gauge overlay..
need the whole black backing plate.
need to do big cruises more often.
my tank is still on about an 1/8 and im just about to hit the 500km mark :happy:. thats better than ive had for a while
Good luck finding a real 200ZR however. Weren't they rare as hens teeth?
Also, beyond rarity what did the ZR have over the ZX? I'd probably prefer the VG30 over an RB20
torque would be the difference from my point of view.
Boz - I really only bought it to save it from being wrecked... he wasn't going to keep it in one piece much longer. When your insurance is sorted out if you're interested, happy to talk :).
Also, C31 laurel, Y31 cima/cedric/gloria, A31 cefiro... I'm sure there is more :P
Chris - Sorry mate only just got your message. It's already here, and I don't really want to drive it until the rego is changed over. You're welcome to come round and have a look if you like, I should be home all arvo. I'll call you a bit later.
Wouldn't an RB20 have considerably less tourque than a VG30?
And Smity, buy them all ;) I shall then dub you Mr 31! And we shall talk when insurance gets sorted. If it ever gets sorted... I was promised an answer by 5pm Friday. No answer as yet...
Did some digging. From the factory the RB20DET had more or less the same power as the VG30ET (one or two HP difference) but 15nm more tourque. I guess the 4valves per cylinder and higher boost/addition of an intercooler really make all the difference.
Where have all the cheap S chassis cars gone? Can't find a turbo, manual S13/S14/180SX for under about $5-6k. Looking on Carsales, Nissan Silvia, Hard Tuned, Boost and here...
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
