I work with a muppet. A "qualified diagnostics technician" who just seized and engine. Came in with a major engine rattle so he started it up and kept the revs up, now im stripping it down, cylinder 1 doesn't move in the bore and the injector has a big hit on it :stupid:
Anyone know a cheap towie?? Need to get an r31 from Bribie island to Fig Tree pocket tomorrow preferably. If you have a tow car with a trailer I will pay for the service.
My Monday turned a bit terrible, I am off to Gladstone to do round the clock monitoring on mutant fish! Still I get paid more money for it so it cant be all bad.
Don't worry isn't all you have to say that there's no problem and its not the governments fault anyway?:nyaanyaa:
Yay for muppets. I'd probably be more helpful and I struggle to remember which way my ratchet needs to go to tighten a nut half the time :P
Boz you need to get Snap-On ratchets, they have On/Off on the switch for dumb americans to use. Watch out when you get a left hand thread though....
Anybody have a cheap set of stock wheels they wish to sell/rent out?
Meisters are coming off on Sunday and my new wheels won't be here for another 6 weeks
i got a set of stock 33 wheels and tires you could borrow, will look quite hilarious under your car.
If I could, that would be great. don't really care how it looks :P
Will pm you later to arrange a journey up to the mysterious north to come pick them up
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
