Are they multi stud John?
I assume not, don't think I've seen any multi stud advans. Would be keen to take them for the ute if they're 4 stud.
oh and Morning Mangs,
So the exhaust has fallen off my car again, at the cat. Needs moar locktite lol. Also I'm getting some terrible squealing noises, sounds like they're coming from the pulleys at the front of the motor...maybe bearings gone in them or something? Anyone know how difficult these are to change?
could be belts, you can always try some baby powder :P
we are simply friendly vultures your yet to meet
Colon, 5 stud.
Misso, you're PM was in before these other vultures that I don't know, so they're yours. Come and get them :)
Colon, 5 stud.
Lol. Pm me your address, number and an alcoholic six pack of choice and we will work out a time.
Please note, if no alcoholic beverage is stipulated it will default to bourbon, and I will possibly drink half of them on my way out there
Colin use different nuts to hold the exhaust together. If you drive it more often those noises don't occur, i stopped driving mine for a while and the damn battery died :whistling:
maccas tonight?
gonna try and sort out a few northerners, and might come visit. ralf has his car back from Dan. and im sure he's keen for a nice drive
Gah stupid f**king cars. Went to fix my exhaust yesterday after its been dangling loose for a day or so and the f**king exhaust is bent. Bought another catback from option 1. Atleast now I've only got to fix the starter, noisy pulleys/belts and the turbos. And clean it. And repaint the front bar. And replace the drivers side mirror...f**king cars.
maccas tonight?
yeah i'm keen. old girl is working so Maccas for me.
I am having a German Club meet in about 27 minutes. Reduced menu at the moment as the kitchen is being overhauled but the pork pie is epic and only $12
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
