not me. fiddling with a car for a bit then going home. two nights a week out gets a bit expensive for me.
Damian, i was slightly wrong. Honda started with the S360, which was the one they barely made any of, before making the S500, S600 and S600. I'm pretty sure that one of the ones that does the car show rounds is a s500, (and the same guy has a 600 or 800), and there's also a 600 or 800 which turns up to some of the shows.
anyone heading out tomorrow night?
im working about 1km further down the road and wondering if i should just bring my car and bum around for a few hours and meet you there?
and if so.....what do i do in that general area for a few hours to entertain myself? any suggestions?
Sit at maccas. Drink a lot of beer. Act like a tool. When mumslayer arrives with his mates, they can put you in the back and take you away. They conveniently have a 4-door.
Gah iPhone. I can't get to the end of the thread. And I don't wanna go thru 1870 pages individually.
Still on for tonight? If anything changes can someone PM me plz with a location etc.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
