Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Don't listen to him Andy its good.
OH! I forgot!! The fried rice isn't even fried! It's the same glue boiled rice they dish up with other crap, but they tossed some veges (95% eschalot, 5% re hydrated peas) and egg in it. Fucking fail.
Edited by Isola
and designed by Renault.
i feel the need to point out that the VQ is in fact a NISSAN engine
just because renault use it for a few of their cars doesn't mean they designed it
clarkson has a lot to answer for with that one :cool:
Whats next? Holden designed the RB30?
Edited by Smity42
Anyone know a decent mechanic that can give me a curtosey car while they service mine?
surely there is a "i will service your ....." joke in there somewhere
i just can't think of one. i think i am getting less funny as i get older
Damn you all and your two less doors and damn your clutches as well!
I was typing and didnt realise that i originally wrote "cl1t5 as well"
NCIS is good and distracting.
Edited by Tony350
Evening gents
*tips hat*
*realises he needs to wear more hats, so that he may tip them more frequently*
Edited by mosquitocoils
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
