So i'll be painting my s1 r33 skyline in a month or so.. and going for a respray i have chosen LP2 midnight purple.. i am all ok for taking off all items. but when it comes down to the glass iv been reading on how to take it out.. it seams like its an bugger of a job,, has any one take there glass out, and what things do i need to expect.
OR... > should i get like o'brian or a pro. to come out and take it off it will probs be a week with it out while i prep and spray . then ill need him to come back. has any one done this or got a quote as for PRICE $$$ or will it be cheaper to drive the car there and get it taken out then just put the front window in with tape or is that just asking for trouble.
Any input would be appreciated
thanx guys..
https://www.sau.com.au/forums/topic/261275-remove-all-windows/
are you paining the car yourself or a panel beater / painter taking care of it?
if you're getting it done professionally they should be able to organise this for you, it's not that expensive i don't think to take them out... about $80 per window from what i last heard, doesn't matter how big or small
if you want to organise painting/window removal/panel beating all at once mate pm me, i'll set you up with something nice, cheap and at awesome quality
cheers,
Andrew
na im doing it my self.. iv panted a few cars befor and my old man has all the equipment.. so im just needing some one to come over and take the glass out then put it back in when im done.. thank you Andrew ay tho whos ur mate it might pay to see how much someone can do it.. its just labour thats so so expencive..
Edited by kleicl
^ yeah, i forgot to mention that bit
in that case, it's probably best to get a pro to come to your house like O'Brien's or Novus and they can remove it and leave it somewhere at your garage and then when it comes to the time to putting it back in just give them another call and Bob's ya uncle ey
thanx i just did some ringing and found this.....
O'brien's are $650 thats for taking all glass out exept the door glass (in store) and then a week later putting it all back in (instore) thats excluding nissan front and rear genuine seals just there generic ones...
And a place called Ed Auto Glass is $611 For ALL AT MY Hone. inc.. new front window (take out and put new in...) also my rear and my sides.. with all genuine seals a week later.. it works out cheaper this way because i get a new front window.. lol
does anyone know or have had there car painted.. and can tell me where or who did theres...
thanx guys
Between $550 and $600 is about what you'll get the two quarters and rear removed and refit, plus the front windscreen supplied and fitted for, not including genuine nissan mouldings, if you want them. As mentioned though, glass is glass, hence we NEVER guarantee it'll come out without breaking, and you'll be up for a lot more. That said, I've removed somewhere in the thousands of glasses and only broken 4, so professionals definately have much better odds than a home job.
Because taping them up is dodgy. Aside from the fact that the rear quarters are encapsulated and touch the paint, hence you will always be able the see the edge line, you will find that if there is any place you'll get rust in your car, it's behind the window moulds. Water can get in there, but takes a long time to dry out, and why paint your whole car if you don't even know if rust will start coming through in 6 months time. Do it once and do it right. Unless you genuinely don't have the money, in which case a cheap re-spray is a long way off the best way to spend what little you have.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
