  • Replies 207
Neons sound good... I am installing an X-box / TV screen / subs / amp / cd player into my car shortly (After timing chain is fixed) and might be after a Small green Neon for above the Xbox in the car... how much for like a 30 cm neon?
MELV,
Thanks for the replacements.... Got them all installed and working today and they look awsome. I will get some photos and post them up soon.
Excelent. good luck with the install. please dont forget to send a photo.
CHEARS
MELV
Hi Melv
Just read through all the posts on this thread and am definately considering doing business with you. Can you send some pics of the aqua and blue through to [email protected] please mate.
Cheers
hey mate if u could send me some pics of blue neons and red if u have them that'd be great, if u can send any others aswell it would be appreciated, i just need to make up my mind about about what colours i want, cheers.
[email protected]
hay melv , got a bright blue line , woundering if you can do yellow as no-one has mentioned it yet , and I am going for a yel/blu theme ? if not pics of other kolors pls to [email protected] . will be in bris vagas in a few weeks so can p/u or come around for a look at least
jaqule, mate we do offer a yellow but the glass is diffrent from the normal (blue green purple red aqua etc) its very very brittle and will break alot easyer and its not as bright. i will send you a email of a few pics i have taken of diffrent colours etc.
Melv,,,I stickied your thread cause I thought it would help everybody who wanted neon's. Now I would like you a donate a bit of your profits to keep this place going. If you can,,,then please contact PranK.
Thanks
Neil.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
