  • Replies 105
hey everyone
thanks for all the emails and very amusing posts.
The shortlist to pick up Paul is:
R34 Z-Tune
Dom from Autostyle blue R34
and a Millenium Jade M-Spec NUR with 19-inch Volks on it
Vin will be going in a decked out Chrysler 300C and/or IS250
hey everyone
R34 Z-Tune
Why?
Universals taste in cars =
Edited by Black Widow
post-9339-1237421205_thumb.jpgwhat about this
hell yeah. I always knew you had taste greg. always been a snapper dresser!
c'mon andrew. as if vin wants to be seen in a 300C. they are just a poor mans caddy in the US. and still a cheapo car here. go the valiant. it's aussie and has some style! and will blow a 300C into the weeds.
hey everyone
R34 Z-Tune
Seriously though, same car??
edit: no it's not, this is a VspecII.... sorry
still think its homo that they can't have outside input.
They've given you the task of helping find these cars. You should have input as to what they use.
We know whats good...
No one else opinions matter :)
actually, enthusiasts aren't their target demographic, if it was they wouldnt get enough viewers. there taret demographic is " as many people as possible to buy tickets"
Cars had to be approved by Universal Australia and US. Publicist had to see it etc etc etc
you work i this industry you get used to it and just deal with it
hey everyone
R34 Z-Tune
not to sound like a party pooper here...
but seriously i dont see the point of all your hype.....
you asked everyone on their opinions....and for everyone to post you pictures of cars to suit...
but at the end of the day... none of the cars you mentioned that were picked ad nothing to do with ANYTHING, anyone has posted..?
so at the end of the day, everyone just wasted their time ?
anyhow
hope the movie is good
coz if not that would be 3 strikes in a row.....
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
