bilsteins on ebay
Just a heads up for those looking at purchasing these for their car.
Make sure you get all specifications and rates etc confirmed before buying.
I have been told they may not be the real deal, or the actual specs etc are not known or similar circumstance.
https://www.sau.com.au/forums/topic/262319-heads-up-about-bilsteins-on-ebay/
Hi Guys,
It was I that asked MAG86 to post this, as I was asked by a few people that were thinking of purchasing these shocks.
I have spoken to Heasman's in Sydney and they tell me they could be the real deal, but are certainly outside of factory spec and the guy wont disclose what the spec is.
For my money, if your not looking at coilovers, I would be looking at Koni regardless of the money.
I stick by the old rule, "IF it sounds too cheap, it usually is" Don't be caught short looking for a deal. Be very sure what your buying before out laying the hard earned cash.
Cheers, D
I can guarantee that these are the real deal. and spec's are available on request, Pm gts145 on here or the R31 club, Or Classic skylines Australia.
Also look at the Seller FeedBack 100%.
More info Here : http://classicskylinesaustralia.com/thefor...php?topic=134.0
http://forum.r31skylineclub.com/index.php?topic=104802.0
"Also look at the Seller FeedBack 100%"
That's bullsh!t, because a 100% perfect feedback can be BOUGHT using ebay's "sqare trade" system.
If you don't like a feedback you can pay square trade and have it removed.
Cheers, D
Cheers, D
Hey Ghostrider and everyone else. These are being sold by me. I am the only person in Australia to have them, and they are the real deal. If anyone has any problems or questions about the authenticity of these Shocks, please ring David at Quadrant on 9769 9666 to verify that I am a legitimate reseller of these shocks. I source them direct from Germany through Quadrant, and have done for over a year. I am the only stockist of R31 Bilsteins in Oz, and had to invest a hell of a lot of money to stock them.
Anyone who knows me, knows that I go to a lot of trouble to source and/or reproduce parts for these cars.
I hope that clears it up. This rumour started when I was asked a question about how adjustable the bilsteins were by an ebay user. I replied that they are not adjustable like Koni's are adjustable, but the rears can be adjusted by height before bolt up. The ebay user accused me of being a fraud after I replied to his question, as he believed all Bilsteins were adjustable, which they are not. Some are, these are not, and never have been.
For the record, my ebay feedback is legit.
Edited by cazz
hey cazz can you let me know the overall length of the front and rears and their travel etc?
im just curious to compare them to the stock R30 items i have that really need replaceing...
and d-limo, i have bought 2nd hand shocks before, kinda been a waste of monay!
Rears are the same as your R30, will get some measurements on fronts for you matey.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
