hi guys,
i am looking at upgrading my cams but i want to know how far i can go with the rb26 head before i need to change buckets & springs...
as far as i am aware tomei pon cams @ IN 260/EX 260 Lift 9.15 is close to the max?
fyi im building an rb30 & my goal is 400+awkw (street setup)
regards,
marko
9.15mm lift. ANy more and you have to machine the head
So:
Tomei Poncam
HKS Step 1
A'PEXi Sttep 1
GReddy Step 1
You can get different durations from every manufacturer, but the lift will all be around 9.1 to 9.15mm
should i look at matching my exhaust cam with my inlet cam taking into consideration the below specs:
A269IN (inlet) 9.15mm lift
A252X (exhuast) 9.15mm lift
...or can the 252degree be adjusted out with the cam gears - NFI
i just went and bought
tomei 270 11.8mm and tomei buckets.. obviously needs work for cam lobe clearance and buckets replaced.
i thought since the bottom end will be pretty soild, the top end deserves a bit of a tickle too..
i'll prob have a set of hks or tomei cams for sale that will suit standard buckets. will get them measured up when i pull em out.
lol, with nearly 12mm lift you will be highly likely to end up with valve meeting piston and any decent rpm... it will certainly need checking and most likely new pistons.
not exactly...there is a way to keep everything friendly. Its doesn't involve pistons either.
Edited by DiRTgarage
yeah of course there are ways to stop it happening, but they only work if you do it before your engine is built. ie it needs to be checked while everything is in the build.
i'm sure my engine builder will not have a problem at all.
nothing has been built yet... slowest build ever perhaps?
then you have nothing to worry about. :(
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
