Hi Guys,
I have a fairly stock R34 GTT, full exhaust, FMIC, pod filter, BOV, AVCR.
I have set low on the AVCR to 0.5bar and high to .75bar.
I have noticed especially on high boost pinging at and above 4000rpm.
What causes pinging, and what sort of things can resolve pinging?
https://www.sau.com.au/forums/topic/262384-pinging/
Too much timing, poor fuel, not enough fuel
So it'll either be your running too much timing, or fuel pump dying and/or blocked fuel filter
I assume your using PULP... so one of the above
I would go and get a FULL service, oils, plugs, filters and THEN put it on a dyno and check the AFR's and go from there
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4494333
Most people can't hear detonation, easiest way to describe the sound is the sound that is made on a geiger counter that detects radiation. This is what you are hearing?
Very rare for the stock ECU (with only such minor mods) to allow such audible detonation at only 4000rpm, hence why im thinking it might be something else that you think is detonation.
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4494989
I've never heard anyone call it "pinking" before either lol It's eithet dotonatin/knocking or pinging.
Anyway, I have tried to hear an engine pinging when the tuner said it was doing it ..and I was right next to the engine with the bonnet up and I couldn't hear shit over the engine noise.
So for you to be able to hear it from your driver seat whilst driving .. hmm, it's either not detonation or you've got some violent detonations and the engine is about to blow up :down:
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4495490
By the way, at the very least you should have your ecu remapped if you can't afford an aftermarket one .. Toshi here in Sydney does a GTT for $400 I believe. He'll fix up your ignition timing and AFRs to prevent detonations
I think there's a guy called Dr Drift down in Melbourne who does the same thing.
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4495506
Just ordered myself a Walbro fuel pump and will be changing that, will also get myself a fuel filter on the weekend.
I have booked my car in for a remap and dyno run with Dr Drift, but he couldn't fit me in till mid may so I will just have to wait until then.
Thanks everyone for all the advice I appreciate it :-)
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4495952
Ended up being fuel. I refilled with BP Ultimate and took it for a squirt and the pinging was gone.
I had bought the fuel filter and fuel pump before refilling so decided to change those anyway. Probably better to have new better stuff anyway.
Still gonna get it tuned though as I have been hanging to do it for a while and this just gave me the push I needed to book it in.
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4505202
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
