Hi Guys,
I have a fairly stock R34 GTT, full exhaust, FMIC, pod filter, BOV, AVCR.
I have set low on the AVCR to 0.5bar and high to .75bar.
I have noticed especially on high boost pinging at and above 4000rpm.
What causes pinging, and what sort of things can resolve pinging?
https://www.sau.com.au/forums/topic/262384-pinging/
Too much timing, poor fuel, not enough fuel
So it'll either be your running too much timing, or fuel pump dying and/or blocked fuel filter
I assume your using PULP... so one of the above
I would go and get a FULL service, oils, plugs, filters and THEN put it on a dyno and check the AFR's and go from there
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4494333
Most people can't hear detonation, easiest way to describe the sound is the sound that is made on a geiger counter that detects radiation. This is what you are hearing?
Very rare for the stock ECU (with only such minor mods) to allow such audible detonation at only 4000rpm, hence why im thinking it might be something else that you think is detonation.
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4494989
I've never heard anyone call it "pinking" before either lol It's eithet dotonatin/knocking or pinging.
Anyway, I have tried to hear an engine pinging when the tuner said it was doing it ..and I was right next to the engine with the bonnet up and I couldn't hear shit over the engine noise.
So for you to be able to hear it from your driver seat whilst driving .. hmm, it's either not detonation or you've got some violent detonations and the engine is about to blow up :down:
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4495490
By the way, at the very least you should have your ecu remapped if you can't afford an aftermarket one .. Toshi here in Sydney does a GTT for $400 I believe. He'll fix up your ignition timing and AFRs to prevent detonations
I think there's a guy called Dr Drift down in Melbourne who does the same thing.
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4495506
Just ordered myself a Walbro fuel pump and will be changing that, will also get myself a fuel filter on the weekend.
I have booked my car in for a remap and dyno run with Dr Drift, but he couldn't fit me in till mid may so I will just have to wait until then.
Thanks everyone for all the advice I appreciate it :-)
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4495952
Ended up being fuel. I refilled with BP Ultimate and took it for a squirt and the pinging was gone.
I had bought the fuel filter and fuel pump before refilling so decided to change those anyway. Probably better to have new better stuff anyway.
Still gonna get it tuned though as I have been hanging to do it for a while and this just gave me the push I needed to book it in.
https://www.sau.com.au/forums/topic/262384-pinging/#findComment-4505202
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
