hey man im after a set of bosch 6000k h3c to fit my cefiro could you please pm me some payment details?
PM sent.
i have a r32gtr with those projector lamps. was just wonderin what bulbs would fit?
Not sure mate, pull one out and have a look.
Get back to me.
  • Replies 115
3 questions. Has any1 fitted these to their high beam as im goin to be doin alot of country driving and want brighter high beams.
Do they make a kit in the phillips that would replace my high beam which has H1R1 or would a normal H1 fit.
Can i get a price on a h1 kit in then phillips in 6000k and the other kit that would suit my car in either 8000k or 10000k
Thanks
Thanks
1. Yes, there are kits for high beams.
2. Never heard of H1R1, might be just H1.
3. $225 for H1 PHILIPS 6000k delivered, i do not recommend anything over 6000k for highbeam as the LUMEN rating is lower as you go higher in KELVIN rating.
Meaning the the higher the KELVIN rating, the brightness starts to drop.
EG: 6000k= 3100 LUMEN
8000k= 2900 LUMEN (this is still approx 3 times brighter than halogens)
Hey thanks for that ill have a look at the light 2morrow and see if a normal h1 will go in there or if its sumthing else. Ill take a photo of the bulb aswell and post it up for you as i think the r34 use these bulbs in their high beams.
done a bit of research and found out that a normal hb3 will fit in my car instead of the HIR1 (misspelt it before). Can i get a price on 3 kits all delivered 2gether. Im after a H1 kit in 6000k, D2R for my lowbeam in 8000k and hb3(9005?) for my high beam in 6000k delivered to Bathurst 2795 Thanks. Ps this is a photo of the bulb that is in my car.
Last batch sent.
There is also a Vega Diamond 4300k H1 kit ready for immediate shipment.
OEM colour with 3x the brightness of halogens.
$160 Delivered.
Suits all R33 GTSTs
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
