Gday Guys,
Im looking at buying my first Jap import for some fun until I get a new company car beginning of 2010.
I just want something thats fairly quick (easy sub 15 quarter) reliable and comfortable. Ability to seat 4 adults is a bonus but not required. I was looking at most of the imports like soarers, RX7s, skylines, 200s, etc
How do the R32 GTS' and the S14 200SX's compare to eachother? I have driven a 200sx with only boost mods and I was impressed with the power and performance.
I don't want to spend more then $10,000
https://www.sau.com.au/forums/topic/262722-best-sub-10k-performance-nissan/
Lots of R33 gtst's around for under $10K
More room in the back than the R32 (not much but still bigger).
thinking outside Nissan stable...
WRX
Lancer GSR
Familia GTX
Celica GT4 (if you're queer)
Galant VR4
Soarer TT
MA70 Supra (if 7mgte engine, get the TYPE A, or get one with a 1jz)
FC RX7 series 4 or 5 (expensive on fuel and expect repairs)
I've had a series 1 S14 200sx and a couple of R32's and liked the 200sx better.. all cars had usual mods.
Currently have an R33 which I'm looking to sell for $9K.
Looking to go t a WRX hatch (need the space).
I've seen a few S14s for under 10gs. I would prefer something I can just pick up and go with. A manual turbo SR20 S13 would probably suffice. I don't really want to have to piss fart around with the car too much with engine swaps and stuff.
Performance wise how do the R32s compare to the S13 and S14 SR20s?
r32 is slower than both silvia (of any series) and r33. s13 is about as fast as a r33 (in stock form).
r32 gts-t = 157kw, 265nm 1320kg
r33 gts-t = 184kw, 295nm, 1370kg
s13 = 151kw, 274nm, 1150kg
s14 = 162kw, 274nm, 1220kg
the r32 makes more power than the s13 by 6w, but 9nm less torque, and weigh 170kg more. r33 weighs 50kg more than the r32 but makes an extra 27kw more power and has a better power to weight ratio.
r33's are generally cheaper than r32's (well there is plenty of good cheap r33's around but not many r32's) and they have more power and are faster.
i have owned both a r33 and a sr20 powered 180sx, and driven a ca powered 180sx and a r32. r32 was least favourite of the lot. r33 and s13 were on par. i like different things about the different cars. for an everyday driver though i think the r33 is better. more low down power and slightly better ride (comfort wise).
s13 has the advantage that you can run 15psi all day everyday and the turbo won't blow up like a skyline turbo that is pushed to it's limit. and you can easilly upgrade to a ball bearing s15 unit cheaply as well.
WRX - Over my budget for a clean one.
Lancer GSR - Again pushing my budget and im not a huge fan of the looks
Familia GTX - whats that?
Celica GT4 (if you're queer) - im no queer!
Galant VR4 - Possibly but again don't like the looks too much
Soarer TT - Would be good but finding a decent cheap one is more difficult
MA70 Supra (if 7mgte engine, get the TYPE A, or get one with a 1jz) - Too old looking for me
FC RX7 series 4 or 5 (expensive on fuel and expect repairs) - Too small and expensive to maintain and run.
I could settle for an R33 but there are just so many of them around my area. Easily as common as XR8s and SS's. Im located in the Northern Suburbs of melbourne. I always thought the R32s were quicker then the 33s or is that just a myth?
I honestly don't know what im looking for in a nissan really. So if you guys come across some that looks the goods can you post it here for my benefit?
Its a Myth. Drive a 32, and then a 33. Then go laugh at the person that told you.
2/4 door Integra Type R :) Quicker than a 32, s13 and s14 (if they are stock :P )
Cheap to run, pretty quick for an 1800 too. And they are coming down in price alot too.
Just a correction.
Aus Delivered S14 is 147kw.. not 162kw.
another nissan to think about is a Pulsar GTiR
almost same power as R33
toughest SR20 ever.
biggest stock T28 turbo on an SR20.
weighs 1220kg
4wd hatch (more room in the back and plenty of traction)
they can be had for $10K ish. (seen some as low as $8K but mainly around $10K - $11K)
downside might be the look.. personal choice..
Familia GTX?? - essentially a combo of Ford Laser and Mazda 323
http://www.turboclub.com/turbocars/mazda/M...milia_GTX_1.jpg
there is also a GTR version of the Familia.
if you can handle FWD, an EP82 Starlet is a good base.
about $5K from stock has them running 12's.
http://pics.hoobly.com/full/P56YQUMOTVEO9ODMCO.jpg
Gday Guys,
That would be an import R31 - a GTS-X.
unless you are talking gtr's then the 33 is the slowest. but in the gts-t's the 32 is the slowest of the lot by nearly half a second over the 1/4 mile, if i remember correctly. and the s13's (sr20 powered) are almost identical to the r33.
and i was able to beat a mates stock rb20 powered cefiro at willowbank by over half a second in a v6 magna (he ran a 15.4 and i ran 14.8)
and my mates r32 i drove had a pfc, bigger turbo and injectors, aftermarket plenum, and made 6hp more than my stock turbo'd, stock ecu r33, except i had full boost by about 2800rpm and he didn't have it until closer to 6000rpm (stupidly big turbo). then they put a smaller turbo on and made a bit less peak power but gained a heap of mid power because he was getting full boost by about 4000rpm.
the r32 may feel faster due to the power delivery though. the r33 basically has the power there all the time so it doesn't feel as quick. i know my 180sx felt much quicker than the 33, despite the fact that it was about 100hp down on power, but because boost came in higher in the rev range you got a bit more of a hit, where as the 33 was pretty much on boost whenever you put your foot down so you weren't really off boost. but then my SSS pulsar (natro sr20) felt, and was, much quicker than the 180 out of slower corners when the 180 wasn't on boost. in fact the missus was driving the pulsar and i was following in the 180 going from her place to mine and out of certain intersections where it was low rpm second gear corners she would pull away 20 or 30m before i came on boost and caught up again, and she wasn't reving up that high before changing gears.
Just a correction.
i did have that mentioned in my post but then changed it and forgot to put it back in
toughest SR20 ever.
weighs 1220kg
hard to find one that doesn't have gearbox/drivetrain issues, or isn't far off having gearbox issues. most have generally had a hard life.
might be the biggest turbo, but is only bush bearing. but they do have quad throttle bodies. they are just a chunkier redtop motor (have a few internal upgrades).
as for more room in the back, the 180sx actually has more room in the back/boot.
i don't mind the look.
sure.. get an R31 if you want something that has the weight of an R33 with less power than an R32.
and worse suspension etc.
Imported R31's, model for model weigh very close to the 32's. Certainly not the 33's. The red top RB20 in them is, again, similar to the silver top version in the 32's.
There is nothing particularly wrong with their suspension - it was a vast improvement over the R30's. The imports have IRS, albeit not quite as good as the 32's.
As for a 33 - well yet another 33 GTS-T will really stand out, wont it.
Personally I wouldn't go near an Australian built R31 unless maybe it was an SVD version. Even then it would only be for its oddball nature. But the 2 door imports can look good if done properly. They share much or their parts with the later models. Plus every man & his dog won't have one just like it.
S13 all the way! Light, awesome chassis and the SR20 is a little doer!!
Not that i'm biased....... :D
I have minor mods pushing over 200rwkw in something that weights just over 1100kg's... recipe for fun!
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
