  • Replies 61
Yep, Matt =)
The graph is for the HKS GTRS's which has an antisurge compressor cover as the only difference. The Garrett -10's most likely surge on a 3ltr! but for 1/2 the price...
I'm thinking HKS do there measurements with a very high RON fuel or at the Flywheel....having said that we made 613kw at the fly on only 22psi and BP98
thats impressive... you can squeeze a few more pounds out of them ! :)
Don't worry we will go 1.8bar on my motor to see what they will do. Identical setup- oh actually different ecu last one was MOTEC mine will just be the PFC. Just weren't willing to push the customers. :devil:
our circuit and drag cars came up with almost identical graphs using the same dyno.
here's the details...
drag gtr...run-in BP98 tune 22psi 455KW HKS GT-RS x 2
circuit gtr...race fuel tune 24psi 451kw HKS T04Z x 1
both were RB26's and torque curves were matched as well.
the race fuel tune on the drag car at 25psi netted an additional 50KW
Edited by DiRTgarage
what size rear housing on the t04z paul?
i'm making 346kw(465hp) out of -5's. 19psi. i honestly believe it would push over 500 easy enough with non standard exhaust manifolds and a bigger exhaust, and some better piping.
Guess what - there have been many cars, stock dumps and stock manifolds that have made 380rwkw @ 20psi :(
he made about the same power as me so i'd assume its the 0.84.
how similar were the 2 engine setups as far as supporting mods go? Same cams/headwork/cam gear settings/intake/exhaust ?
very similar...
both built 87mm bore engines...both with extensive headwork including 1mm oversize valves...both with 280+ deg cams...both with Hypertune plenums (6 throttle on the circuit car and single throttle on the drag car) both with big intercoolers (Apexi drag on the circuit car, Trust drag on the other) both with similar exhausts 3 1/2" circuit 4" drag, both running Power FC (recently upgraded both cars to Vi-PEC ecu's) , Z32 AFM's and Blitz dual soliniod EBC's
We really had to push the circuit car to crack 450KW...the drag car was slightly better everywhere and did it with the GT-RS's without even raising a sweat.
My vote for simplicity would be T04Z as they are easier to get them to perform...but for best results the GT-RS's are the pick if you know how to set them up correctly.
The T04Z is more forgiving if the set-up is lacking in an area...the GT-RS's wont let you get away with it...everything must be spot-on. A 3 litre bottom end may make it a little easier to get right as the extra capacity will help them.
very similar...
Hey,
Looks like an awesome comparo - with the exception of the exhausts.
I mean, there's a 25% difference in cross-sectional area between 3.5" and 4" and at peak flow you're asking for as much flow (and as little resistance) as possible.
Because they're physically different configurations it's a big ask to put one exhaust onto the other car.
Any chance of strapping both cars down minus as-much-of-the-exhaust-as-possible?
It would be interesting to see what (if any) difference it makes to the individual results and to the comparison.
Maybe it won't make a difference at all...
Cheers,
Saliya
Hey,
Cheers,
Saliya
no chance
If you have the -10's already then im sure you'll be happy. But as food for thought, here is my t04z dyno graph.
As you can see, 1 bar at 4krpm, full boost by 4500.. and it makes close to peak power by 6000 rpm. Put the same thing on a 3 litre bottom end, and you would probably have 24psi before 4000rpm!
p.s. both combinations are good for at least 100 more hp than what your goal is. but i guess that leaves you plenty of room when you want to chase more power :blink:
best of luck, let us know how you go.
Wow that is a nice a power curve for a single.
What compression ratio is in that 3L?
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
