if your fan clutch is screwed it will be locked on even when the engine is warming up. you can tell this by getting under the bonnet and revving the engine. if the fan makes a massive roaring noise so you can hardly hear the motor for more than a few seconds at a time (providing the engine is not very hot) check it on a cold day. if the fan roars for a few seconds and turns off it is working fine. mine locked on in my 31 i used2 own and the motor had f**k all power and chewed the fuel. those fans pump a shitload of air and take about 30hp out at 5000rpm.
also like many others have said you should sit in fourth or third. labouring the car will make it use more fuel as the engine is trying to boost even tho the guage says its not so the injectors are pumping shitloads of juice in in an attempt to get more revs when you touch the throttle even a tiny bit. but it will respond slow and chew juice. hope this helps.
do you stil run an the AFMs or is it running in D-Jetro mode with MAP sensors?
hello
what causes bad fuel economy?
constantly loading the engine up
constantly loading the engine up & bringing it on boost
poor state of tune
failed 02 sensors
02 sensor closed loop turned off
poor throttle control
bad setup injection control
based on what ive seen and read in here i would check 02 feedback is turned on in the hand controller
this is covered in the PFC FAQ (in my signature) check that first, it should be ON by default.
has the tuner tuned your light cruise cells with a wideband sensor?
don't assume this has been done, not all tuners do it, some only do it when you ask
without this light cruise tuning the fuel control (esp with big injectors) can be a bit simplistic so not as good as a well light cruise tuned setup
forget all this rubbish about boost and gears and other crap
none of this bears any relevant to light cruise economy
ie; in light cruise the engine is in (or near) vacuum and boost means nothing
driving around in 4th, 5th or 6th shouldnt post much difference
unless you are doing 50km/h in 6th and have to use %100 throttle to maintain road speed
also check the simple things - are you really filling the tank? are you going near empty?
the skylines usually go way past E before they run out and the light comes on
check tyre pressure and other simple things
and last but not least if you still cant get good economy
give your car with a full tank to a friend or girlfriend or mum
i get they can get over 400km+ to a tank - ie; its probably your driving style
light throttle in low rpm is usually best
constantly loading the engine on boost is bad and will waste fuel (amplified with poor state of tune - ie: a simplistic max power tune)
Paul, you are a fu(king genius. I would kiss you if you were a woman.
The O2 feedback control was set to OFF. No bloody wonder I got bad fuel economy.
This should improve my economy. Will post up improvement in results after next tank goes in. Just cannot believe it was something as simple as this.
If my tuner tuned the new turbos and AFRs with the setting on OFF, do I then need to get him to re-tune it now that it is set to ON? Will it lean out the AFR too much?
Thanks so much!
Tuning is always done with feedback off, for clarity. You tuner probably just forgot to turn it back on when he finished...You definatly dont need a re-tune.
Good find - it will be interesting to see what you get on the next tank!
Cool, thanks. Yeah, can't wait to see what difference it makes.
Hmmm quite disappointing.
With 02 sensor feedback turned ON there was no difference in fuel economy.
Still getting 15.6L/100km for mixed city/hwy driving. I drive the same roads on the same days at the same time with the same traffic conditions and driving style all the time, so there is hardly any variation.
The obvious differences that I noticed though, were
O2 sensor feedback OFF
- Smoother idle
- Both 02 sensor voltages 0.00 at idle. Both are responsive and increase similarly when throttling. On cruise, around 0.04 for both.
O2 sensor feedback ON
- Lumpier idle
- O2 sensor 1 voltage around 0.80 at idle, O2 sensor 2 voltage 0.00. When cruising, O2 sensors are around 0.80 and swap around continually
Might need your help deciphering this guys.
Thanks very much.
How do you know the O2 reg is off??
Hmmm,
i got the same problem :stupid:
my O2 sensor feedback is set to on but the O2 reg is set to off?
what does that do?
also my throttle bodies dont seal 100% due to the fact the teflon coating is no more.
02 reg is for BNR32
as BNR32 and BCNR33 use same model PFC they need to alter between the different style of 02 sensors
For BNR32
02 feedback on, 02 register on
BCNR33
02 feedback on, 02 register off
if you have BCNR33 and 02 register is on youll get shit economy
if you have BCNR32 and 02 register is off youll get shit economy
make sure you are checking the correct symbol
heres what they look like;
the on / off tells it to speak to the 02 sensors in titania languge vs normal lambda or whatever it is
if you have BNR34 02 register should be off, however im not even sure 02 register is an option in BNR34 PFC
I have r33 s2 and this is what Ive been getting per 100KMS.
Just so you guys can compare your own cars. Mods are as per my signature.
11.3L, 11.2L 11.5L 12.6L 11.25L 12.6L 12.4L 10.5L 10.9L 11.3L
Used mainly mobil and bp petrol. Every single test, the driving was mixed, bit of freeway, bit of city and bit of thrashing.
How i measured it:
fill up full tank. 50L, drive and if i get say 450KMS, i would 50L/45km=11.1L
I would love to hear what others are getting?
Just had the car serviced today. My mechanic could not detect any intake leaks and the fuel filter was pristine, so he didn't change it.
The mystery continues :D
Still think it has something to do with my faulty boost sensor...
im in melbourne, keilor downs
will be easier to come over and we can sort it out
Paul, are you talking to me or joeleo87? He lives in Adelaide.
How i measured it:
i got 17 the other week :D something is wrong!!
boost gauge i put in recently is reading slightly less vac @ idle than it used to (18inHg vs 20inHg before), but car is boosting and idling fine so i dunno if there's a leak somewhere.
i babied the sh*t out of it last week (NO boosting, rolling down hills in neutral, no driving in traffic) and still returned 14.5L/100km.
ideas anyone? im getting it looked at over the weekend, but it's still worrying me!
as per the post above - with the engine rpm increasing it just gets noisier!
Ian
I'm going to do a full post on this, but just a quick comment - mine was definitely the clutch fan. I''ve dropped back to my normal fuel economy since replacing it - in fact with everything I've done to find the problem (air filter, petrol filter, spark plugs, fuel injectors, ecu reset, replace o2 sensor, normal oil and filter change, and probably other things I can't remember. Plus new tires and brakes....) with the final one being the clutch fan - I've got better than ever ie I got 9.8l/100km last weekend when I did a 300km country drive sitting mainly on 100/110km/h..
That is better than when my car was two years old (when I got it) when I got 10.0l/100km on the same 300km trip. Maybe the wind gave me the better .2 this time!
The point is, I was getting 20l/100km around town before, and 16l/100km country. All the other things improved it a bit, but the final bigy was the clutch fan - so do check it! A brand new one cost me less than $200..
Ian
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
