can it be done? yes
does it work? yes
whats needed? wiring changes & youll loose VCt and some other gotchas
is it worth it? probably not
easier to buy R33 RB25DET PowerFC- should be around $1k at the most
sell your GTR PFC and buy that, about $200 swap over easy
i am guessing he wants to piss off his afm so thats why he has the Djetro, although its alot of messing around when there are other options out there that work out of the box and still piss off that pesky AFM
It says L Jetro in the title and pos.
can it be done? yes
does it work? yes
i have a gtst power fc in my skyline r33. i'm maxing out my afm.
i'm now building a 240sx wide body with a rb25det swap. one of my friends gave me a gtr r32 powerfc. so it realy cost my nothing.
if i can run 2 afm i can get about 600+hp. The vct i can use a handa vtech contoller. and i have a map to about 9200 RPM's with the GTR's power fc. I'm planing building the motor all the way. i want it to be a 9000 RPM motor.
this is why i think it's worth it.
can anyone point me in the right direction.? thanks again.
Their ARE options after running out of AFM other than 26 PFC either D jetro or L jetro. I have my Z32 MAF in 100mm pipe, but I'm not totally happy with it. Aftermarket AFM's for Ford Mustang/Lightenings seem like a great alternative for under $300USD. You in the states?
yes i'm in the states.
i also tried the in a pipe method. it works, but i also wasn't to happy with the set up. (totally)
ok with the rb25det when i change cams there goes the vct. so with the r32 gtr powerfc i don't have to worry about loosing the vct because we would have changed cams on the new set up witch will be a 9000 RPM motor.
the other gain i think is running 2 afm z32 (30p00) this should take the max power output to 1000hp. is this a right.?
another gain is the mapping for the r33 gtst powerfc only goes to 8000 RPMs. the r32 gtr power fc goes to 9200 RPMs.
what do you think about the pros and cons for a 800+ hp set up?
can the r32 gtr powerfc do the job on a rb25det.? ljetro set up
how would i go about uising a ford lighting afm.
wiring.
and putting new values in the powerfc
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
